120mm German Infantryman
    Hello all
    mmm First SIG on the forum for me should be fun
    The box
    [ATTACH]37382.vB[/ATTACH]
    The small sprue
    [ATTACH]37383.vB[/ATTACH]
    The large sprue
    [ATTACH]37384.vB[/ATTACH]
    More to come!!!
    Regards
    David
    [ATTACH]41569.IPB[/ATTACH]
    [ATTACH]41570.IPB[/ATTACH]
    [ATTACH]41571.IPB[/ATTACH]
    Good luck David.
    • mossiepilot
      • Jul 2011
      • 2272
      One day I might be brave enough.
      But not today.
      Can't wait to see more.
      Tony.
        • 18272
        Look forward to seeing it come together David.
        Tony. Just take a deep breath and go for it! I did and it wasn't that bad. Was it?
          Will be good to compare notes...I'm also building this one and having a rough time of it! lol
            Ajay
            No worries fella. Mines at the just built stage with a bit of primer on it so I'm a little bit behind I think, where are you having troubles?
              Making the seam lines disappear. I've filled and wet and dried, and also tried using super glue, but there is still a faint seam line. It's difficult to do without losing details. Think I prefer planes....lol
                Small update
                Build complete and the legs have been primed.
                [ATTACH]37403.vB[/ATTACH]
                [ATTACH]37404.vB[/ATTACH]
                [ATTACH]37405.vB[/ATTACH]
                [ATTACH]37406.vB[/ATTACH]
                More to come...
                Regards
                David
                [ATTACH]41590.IPB[/ATTACH]
                [ATTACH]41591.IPB[/ATTACH]
                [ATTACH]41592.IPB[/ATTACH]
                [ATTACH]41593.IPB[/ATTACH]
                  Ajay
                  I take it you're talking about the ones in the legs mainly on the outside of the legs??
                  I have the same so I'm going to try something if it works I'll let you know and I'll take some photo's as well
                    Ajay
                    There is a deeper seem from what I can make out that one must stay as it is. However there is a faint seem between the two torso parts I've used Vallejo plastic putty applied with a cocktail stick don't put to much on
                    then with a cotton bud make it damp not soaking wet and wipe accross the seem then paint over that if there is still a seem keep repeting until it goes.
                    Sorry no photo's as the plastic putty dries very quickly when applied in small amounts.
                    You need to build it up slowly.
                    Hope it helps
                    Regards
                    David
                      Cheers, David. I have some Vallejo plastic putty so will give it a try.
                        Remember small amounts to build it up slowly
                          Update
                          Hello all
                          sorry got a bit carried away but stopped to take a few photos lol
                          [ATTACH]37920.vB[/ATTACH]
                          Almost all the base colours are now on I hope you can see I've done some dry brushing on the magazine pouches I mixed Vallejo Canvas and light flesh for the colouring.
                          [ATTACH]37921.vB[/ATTACH]
                          Full view and I remembered to reapply some base flesh on the nose and chin lol
                          [ATTACH]37922.vB[/ATTACH]
                          Most of the work done so far has on the personal kit, I've tried something new this time, something I tried on a pilots seat that I've just painted and it didn't look to bad so thought I'd try it on this figure.
                          What I've for the gas mask canister, entrenching tool and knife is to paint them flat black, then dry brush black grey, light grey and finally light flesh for the highlights and to give the kit that beaten up war used look, I've still to do the wooden handle of the entrenching tool. As for the paints I've used the following
                          Vallejo model air flat black 71057
                          Vallejo model air flat black grey 71056
                          Vallejo model air flat light grey 71050
                          Vallejo model colour light flesh 70928
                          [ATTACH]37923.vB[/ATTACH]
                          A close up
                          [ATTACH]37924.vB[/ATTACH]
                          I thought I'd try the same idea on the boots but this time I used the following
                          Tamiya XF-1 flat black
                          Tamiya XF-69 NATO black
                          Tamiya XF-53 Neutral grey
                          As this will be the last update on this figure for this |(crumbs where did the year go?????) I wish you all a happy new year.
                          Regards
                          David
                          [ATTACH]42047.IPB[/ATTACH]
                          [ATTACH]42048.IPB[/ATTACH]
                          [ATTACH]42049.IPB[/ATTACH]
                          [ATTACH]42050.IPB[/ATTACH]
                          [ATTACH]42051.IPB[/ATTACH]
                            Top marks David, looks stunning.
                            Happy new year to u 2.
                            • spanner570
                              • 15482
                              Marvellous paintwork there David, it looks really well.
                              I must confess that with my SIG 1/16 Tamiya figure I just couldn't get on with his big 'conk' (I suspect they all have the same face) so I have filed it down a bit!! lol
                              A happy New Year to you too.
                              Ron
