Stona's Crashed Fw190. A classic "fliegerdenkmal"
  • stona
    • Jul 2008
    • 9889
    This was to be an entry in the now long finished "Crash SIG". I now have time to actually build it. This dodgy scan (not sure why) from Peter Rodeicke's "Fw190 Jagdfluzeug" is going to be the subject.
    This is the result of a botched landing by Fw. Albert Wittmann at Aalborg-Ost. It is an absolutely classic "fliegerdenkmal" or pilot's monument.
    I'm not going to replicate this exactly as is my wont. I will base a little diorama on it.
    Here's the kit.
    I've never built a 1/72 Tamiya kit! It looks very nice indeed.
    Here's the sprues.
    I'll hopefully get this going over the next week or so,work permitting.
    • 22771
    Nice 1 Steve and the CRASH SIG doesn't finish untill the end of August so still plenty of time
      • 18271
      :lookupthere: what he said.
      There is loads of time until the end of the SIG,
      • stona
        • Jul 2008
        • 9889
        Cripes,I thought the SIG was already finished!
        Ian,if this should be moved to some "under construction" thread please do so. I'll definitely be done by August,these little kits have less parts than the cockpit in my normal scale
          • 18271
          As good as done!
          • stona
            • Jul 2008
            • 9889
            Originally posted by \
            As good as done!
            Why thank you sir!
              That's some landing!!
              Did he come straight down... :cheesygrin:
              • Dave W
                • Jan 2011
                • 4713
                My guess is his brakes failed,went off the runway,wheels dug into soft ground and it ended up on its nose.Must have been interesting trying to get out of the cockpit!.If it had come straight down from the sky at that angle there wouldnt have been much left of it!.
                  Wow thats a "fliegerdenkmal" for sure .looking forward to seeing it build out Steve!
                  • stona
                    • Jul 2008
                    • 9889
                    The fliegerdenkmal was the result of "einer missgluckten einradlandung" so he only had one main wheel down,something I will reflect in the model.
                    • stona
                      • Jul 2008
                      • 9889
                      I've made a modest start on the cockpit. I so rarely do 1/72 that I've had two surprises! First it is bl**dy small and second actually quite well detailed.
                      I will definitely weather this a bit and add some kind of harness as the final model will have the canopy open. The shoulder straps will have to hang down convincingly.
                      • stona
                        • Jul 2008
                        • 9889
                        Mmmm! even this well engineered kit needs a little bit of persuasion.
                        This to fit the wheel well insert!
                        • yak face
                          • Jun 2009
                          • 13848
                          • Tony
                          Brilliant subject steve , and it looks a real nice kit too , great work on the cockpit , we'll have you doing 1/144 before long !!! cheers tony
                          • stona
                            • Jul 2008
                            • 9889
                            Tony this little kit is superb. I've been impressed with the larger scale Tamiya models but this is better from an engineering point of view.
                            As a fellow aircraft modeller you will know what a mess some kits make of the wing - fuselage join,particularly the "tongue" that runs to the rear of the wing on the underside of the fuselage.
                            Well,take a look at this,no filler and no filing or sanding of the parts.
                            I'm impressed!
                              That is impressive ... so far i've needed a tub of polyfiller for the 1/72 aircraft i've done
                              Looks like you're on a winner mate
