ARNHEM: Major General R E URQUHART'S HIDE OUT HOUSE Zwarteweg 14
I see you've filled the MG aperture in the Saukopf mantlet - should be easy enough to restore the paintwork.
The foliage looks really promising to me and you've done extremely well to get the plotter to cut such small pieces. I think with a bit of variation in the colour of the leaves it will really look the part and look great on the Stug.
P
I use EZ wire for aircraft aerials etc should be perfect for the cables although it won't have any sag. I think John stocks it in the shop or a product very similar.
Thanks Steve, that's a good one, did't think about that one, will see if my local sewing shop has something like that.
Thanks Paul, yep paint work is already restored. Still experimenting on the foliage first time i try to do it like this. I had a look at the EZ wire but it is really difficult to get here, in Germany so as soon John has it in the shop i will get me some. In the mean time i will try to get some knitting in elastic to see how that works.
Thanks again Guy's and Girl for the input and compliments and comments really appreciate that.
Never seen/heard of plotters before. I was hoping it was a punch and die set up. I ended up contacting some manufacturers in the craft market to see if they would produce some leaf cutters suitable for 1/35. One company went as far as making a demo model - a basic punch with a range of different leaf heads that could be swapped over. It needed some refinement but I thought it had potential. Sadly the company didn't.
No Sorry its a cutting plotter, but it also can be used for drawings and vinyl cutting, it would be cool though and if it was a punch and die I would definitely buy one.
I can only offer you to cut some out of white paper and send them over.
So here's a small update, made some leaves in different tones and detailed them a little and pushed in some detail in the form.
[ATTACH]96481.IPB[/ATTACH]
[ATTACH]96482.IPB[/ATTACH]
[ATTACH]96483.IPB[/ATTACH]
[ATTACH]96484.IPB[/ATTACH]
Then I started with the tree branches on the Stug put together from 2 different kinds, first some top pieces from a plant and glued some sea moose branches to it and fitted theme on the Stug.
[ATTACH]96485.IPB[/ATTACH]
[ATTACH]96486.IPB[/ATTACH]
[ATTACH]96487.IPB[/ATTACH]
[ATTACH]96488.IPB[/ATTACH]
[ATTACH]96489.IPB[/ATTACH]
[ATTACH]96490.IPB[/ATTACH]
[ATTACH]96491.IPB[/ATTACH]
[ATTACH]96492.IPB[/ATTACH]
[ATTACH]96493.IPB[/ATTACH]
[ATTACH]96494.IPB[/ATTACH]
[ATTACH]96495.IPB[/ATTACH]
[ATTACH]96496.IPB[/ATTACH]
next up is painting the branches and put the leaves on and paint them with heavy diluted oils / acrylics.
then its on too the side plate armor. I decided, not to use all of them but lets see how it turns out.
