ARNHEM: Major General R E URQUHART'S HIDE OUT HOUSE Zwarteweg 14
yes I used 2 6mm sheets for the walls. except for the 2 pieces behind the small part that separates the 2 doors there I used 2 scheets of 3mm and 1 of 2mm in the middle.
next up is the first layer of paint for the walls and then I will close the spaces between the stones with plaster.
and I will try to build the doors and windows between that.
