Daves 1/28 Sopwith Camel
  • BBdave
    • Aug 2014
    • 825
    Well here's the kit I bought it as 1/24 but it looks to be 1/28 there's not much to it so I'll try to add what i can detail wise if it needs it the wings weigh a ton, as to colour scheme Im still trying to decide there's plenty of bright jobs to choose from.
    [ATTACH]95609.IPB[/ATTACH]
    [ATTACH]95610.IPB[/ATTACH]
    [ATTACH]95611.IPB[/ATTACH]
    Maybe the oldest aircraft on the SSIG...lovely
    You will have some work with the rigging :P
    PS: thanks for join in Dave
    • flyjoe180
      • Jan 2012
      • 12429
      • Joe
      • Earth
      I'll enjoy watching this one, a nice change from the monoplanes.
      • monica
        • Oct 2013
        • 15169
        nice pick Dave,I'll enjoy watching this one
        • BBdave
          • Aug 2014
          • 825
          I think the bit that'll make or break it is the rigging but hopefully in this scale it will be easiero_O
            • 18271
            I'm quite looking forwards to this one. As you pointed out Dave, loads of different schemes to finish her in!
            • tr1ckey66
              • Mar 2009
              • 3592
              The first biplane of the SSIG (possibly the only one). This will be a really interesting build Dave and I'm really looking forward to it.
              Paul
                • 22771
                Just seen this one Dave, a great choice looking forward to this
                • BBdave
                  • Aug 2014
                  • 825
                  A start has been made I've had a fair bit on the last few months and now there's a lull I thought I'd get the camel out. There seems to be plenty of flash to clean off but luckily not many parts.
                  [ATTACH]115705.IPB[/ATTACH]
                    Nice start!!
                    • flyjoe180
                      • Jan 2012
                      • 12429
                      • Joe
                      • Earth
                      Good to see this one getting of the starting blocks Dave, looking forward to following the build.
                        The rigging at this scale will require wire rope!
                        • BBdave
                          • Aug 2014
                          • 825
                          My dad has supplied me with some literature and using these a few small alterations have been made but one main one is shouting to be done the lower wing should have a dihedral of 5.5° the supplied wing is nowhere near but I've never altered a kit to this extent so do I do it or live with it.
                          I realise I'll need to alter the inter wing struts etc. But I don't think it'll look right at this scale without the correct dihedral.
                          Shall I take on the challenge?
                          • yak face
                            • Jun 2009
                            • 13842
                            • Tony
                            Go for it Dave! at this scale it would be very noticeable especially now youve highlighted it - every time you looked at the completed model you would be drawn to it and think "why didnt i correct that!"! It should be fairly easy once you know how much to bend the wings up by. Its a one piece wing isnt it , I would try immersing it in some fairly hot but not boiling water then after a few minutes take it out and put something of the right size under each wing tip and a weight on the middle then leave it to cool and hopefully it'll reset in the correct 'bent' position . This might mean the outer interplane struts are a touch too long but thats easily sorted ,just cut them down a bit . On the other hand they could be ok - perhaps the kit wing is supposed to have a dihedral and has just straightened out in the box with age? hope this helps , cheers tony
                            • BBdave
                              • Aug 2014
                              • 825
                              The deed is done it was easier than I thought I was going to cut and re glue but the hot water seems to have done the trick, thank you.
                              [ATTACH]116018.IPB[/ATTACH]
                              [ATTACH]116019.IPB[/ATTACH]
