Aarons 1/72 Tiger 1
  • aaron
    • Oct 2011
    • 2019
    Aarons 1/72 Tiger 1
    Finally arrived, super keen to get started.
    The issues I've found with the kit are not issues to me, if that makes sense. Molded on tools, closed hatches, and some unusable figures due to closed hatches also no p.e grills but it has moulded Zimmerit so I'm still happy.
    I got the kit for NZD 19.35.
    [ATTACH]96810.IPB[/ATTACH]
    [ATTACH]96811.IPB[/ATTACH]
    And it came with a full figure set which is the scaled down "tiger aces" figure kit. I do not plan on using them.
    [ATTACH]96812.IPB[/ATTACH]
    Danke.
  • flyjoe180
    • Jan 2012
    • 12426
    • Joe
    • Earth
    Nice one Aaron, it finally arrived! I have the 1/72 Hasegawa Tiger I waiting for the day when I take a plunge into armour. Will watch to see how you do yours.
    • aaron
      • Oct 2011
      • 2019
      It took 16 days from across the pond.
      I have seen the hasegawa tiger, we could have done a buddy build.
      My next post in this should be the completed build right?
      • flyjoe180
        • Jan 2012
        • 12426
        • Joe
        • Earth
        16 days is a long time to wait! Maybe later if you have another, we could do a buddy build. Normally we post progress shots and comments along the way and then present the finished build in the completed section. I've got no idea on tanks so seeing the progress of this one will help me with mine later. Aircraft are easy enough to build and paint, their construction is pretty straight forward, but these things have lots of extra bits hanging off them so I am interested in seeing one go together in stages.
        • aaron
          • Oct 2011
          • 2019
          I forget to take pics when I'm in my zone, but I'll try to take some for you bro, funny because I feel like most Armour is easy to build but struggle with aircraft.
            Wow! This will be a paintwork challenge! After a look at your tiny last tank, I'm sure this will be magnificent!
            • aaron
              • Oct 2011
              • 2019
              Hey Polux mate, I'm stressing on how to treat the zim when it's wash time.
              I'll be want to accentuate the zim pattern but not overwhelm the base colour.
              To be honest the kit has a few fit issues and broken instructions, but it's all good.
                I'm interested to see how this one goes together Aaron as I was tempted to buy one myself!
                Some of the newer Dragon 1/72 kits are said to be poorer than their predecessors, which is what stopped me.
                Patrick
                • aaron
                  • Oct 2011
                  • 2019
                  Patrick the Dragon 1/72 initial production is apparently a dream to build, so that is on my list.
                  I'm finding this kit is fun but querkey in places. Definitely a wise decision to steer clear, but then again the figure set is really nice.
                  • aaron
                    • Oct 2011
                    • 2019
                    An update just to show some progress
                    I wish I could put the first 3 pics together as one. They show the turret mg, none of this is in the instructions and the mantle had a little half hole so out with the pin vice.
                    [ATTACH]96951.IPB[/ATTACH]
                    [ATTACH]96952.IPB[/ATTACH]
                    [ATTACH]96953.IPB[/ATTACH]
                    I added slots with a heated screwdriver, these were missing.
                    [ATTACH]96954.IPB[/ATTACH]
                    Unused holes filled with stretched sprue, waiting putty.[ATTACH]96955.IPB[/ATTACH]
                    I drilled a hole and used sprue as a tow lock. No idea if this is cannon or not but it adds a little detail.
                    [ATTACH]96956.IPB[/ATTACH]
                    And finally I added wired to the light, I've seen this done on 1/35 scale so I thought I'd give it a go.
                    [ATTACH]96957.IPB[/ATTACH]
                    Thanks for looking, sorry it's so pic heavy.
                    I haven't started on the running gear yet because I know it has issues with the idlers.
                    • flyjoe180
                      • Jan 2012
                      • 12426
                      • Joe
                      • Earth
                      Great little update Aaron, thanks for posting these.
                        I did add a headlight wire to my King Tiger, some thin fusewire worked well.
                        The quality of the tools moulding is abysmal! I'd expect much better for a lot that retails around the £20 mark!
                        The unused holes on the upper deck are the tow cable brackets, so I assume you're not using them Aaron?
                        • rickoshea52
                          • Dec 2011
                          • 4076
                          • Rick
                          Can we fast forward to the weathering bit please? After seeing your Elefant I'm itching to see what you do with this one!
                          • aaron
                            • Oct 2011
                            • 2019
                            Nah mate they give 1/4 of what's needed for tow cables. I thought about taking the hooks and drilling them out but it's just too much work .
                            I agree about the tools being a freaking wreck.
                            Cheers Joe and Rick, It is kind of refreshing to have some stuff to do on this kit, my last Dragon kit in this scale fell together so easily that my modeling beast was barely fed.
                            • Richi72
                              • Sep 2013
                              • 1100
                              Nice start there Aaron,
                              really admire what you get out on a 1/72 model.
                              well I must wait for the next update
                              Cheers Richi
