Late starter, but I have already done much research for this kit and build so will get into it and report back with updates.
So far I know that:
1. The kit represents a later B-17F version than that of either Memphis Belle, or Miss Ouachita, the second kit option.
2. The nose-mounted astrodome mount must be removed and a new window installed ahead of the windshield. The astrodome replaced two small windows above the navigator/bomb aimer positions in later versions of the B-17F and on all versions of the B-17G. Memphis Belle had the earlier window configuration.
3. I'll have to add more armament to the nose section. I think the drill may get a work out.
4. There are a few discrepancies (as you get often with Academy kits) with colours. I have sorted them out already. Luckily the Belle was an often-photographed aeroplane.
5. Academy's B-17s suffer from excessive dihedral. Should be easily fixed with some spacers from plastic card.
6. The starboard tail fin panel came from another B-17 and is a slightly different shade of OD.
7. The control surfaces were faded and appear lighter in photos of the aircraft than the rest of the upper surfaces.
Sprue/box shots to come soon. Looking forward to this
So far I know that:
