Neil's Airfix 1/72 Fairey Swordfish
    Hi all.
    Now I know it's late, but hopefully I'm going to try and sneak this in before the finish date.
    Its the new-tool version of the Fairey Swordfish. A lovely little kit with loads of detail, light-years ahead of the old Airfix model.
    It's going to be OOB, but hopefully crewed and ona small base, if time allows.
    A box shot, and scenes of the started cockpit.....
    [ATTACH]114815.IPB[/ATTACH]
    [ATTACH]114816.IPB[/ATTACH]
    [ATTACH]114817.IPB[/ATTACH]
    [ATTACH]114818.IPB[/ATTACH]
    [ATTACH]114819.IPB[/ATTACH]
    Cheers, Neil
    An interesting little kit there Neil! Look forward to seeing more
      Nice painting on the small cockpit. It's good to see positive things about the airfix kits now
        Nice choice Neil!!
        You can take all the time you need, to build this little beauty!! Don't worry!!
        • flyjoe180
          • Jan 2012
          • 12407
          • Joe
          • Earth
          Nice choice Neil, looking forward to following this build.
            • 22770
            Nice choice watching all the way Neil
              OK, cockpit basically done. I've not gone too mad as hopefully it'll be stuffed full of crew
              Cheers, Neil
              [ATTACH]115159.IPB[/ATTACH]
              [ATTACH]115160.IPB[/ATTACH]
              [ATTACH]115161.IPB[/ATTACH]
                • 22770
                Great work Neil.
                That's a lot better than the old one I did a few years ago some great detail
                • flyjoe180
                  • Jan 2012
                  • 12407
                  • Joe
                  • Earth
                  Looks good Neil, there is a fair amount of detail in there already. As you say the crew will hide most of it.
                    Hi all. Managed to get quite a bit done. You're right Ian, it's a lovely kit with lots of little detail on it.
                    A couple of points I've found though. I really don't like 3 piece fuselages, I just can't seem to get on with them.
                    And this kit doesn't allow you to assemble the airframe with just the lower wings attached, which is a bit of a problem for painting. So I'm going to try doing it with the upper and lower wings assembled, paint both them and the fuselage, then complete.
                    That's the plan, anyway.....
                    [ATTACH]115315.IPB[/ATTACH]
                    [ATTACH]115316.IPB[/ATTACH]
                    [ATTACH]115317.IPB[/ATTACH]
                    [ATTACH]115318.IPB[/ATTACH]
                    • colin m
                      • 8755
                      • Colin
                      • Stafford, UK
                      Good progress Neil,
                      I built the float version sometime ago and certainly agree it's a great kit to build.
                        An overdue update!!! Main construction done, a bit of masking still to do, and then to paint....
                        [ATTACH]116794.IPB[/ATTACH]
                        [ATTACH]116795.IPB[/ATTACH]
                        Cheers, Neil
                        • flyjoe180
                          • Jan 2012
                          • 12407
                          • Joe
                          • Earth
                          Good work on the sub assemblies Neil. Looking forward to paint and rigging pics
