Tommy1drops Panther G's
    These are the two I'm building for this group build.
    They are both Panther G's, the Tamiya version is the Panther G early, and the Dragon is the steel wheeled version.
    I'm going to be building these at the same time, so I will update as the builds get going
    Always nice to see more Panthers Tom! I know the Tamiya one builds into a nice model, albeit lacking certain features like weld seams.
    Watch out for the  'Dragon' kit though. If I'm not much mistaken, the mould is actually from Gunze Sangyo. DML took inherited the GS moulds back in their fledgling days & some need very careful assembly.
    • grumpa
      • Jan 2015
      • 6142
      Two awesome kits imo, though "Dragons" can have YOU breathing fire over fit problems >  Building a Dragon Imperial Series SU76 and had to cut lip for mounting fenders off because tracks would not fit onto track support rollers :S  Will be watching you progress..........Cheers...Jim
      • monica
        • Oct 2013
        • 15169
        will be watching these two builds,Tommy do like the panthers as well, 9_9
        I do have one of these in my stash as well,but after reading ,the comments from,Patrick,Jim,I hope its
        not the Dragon,kit,wish you luck,and if you run into problems sure someone will be able to help, 9_9
        • tr1ckey66
          • Mar 2009
          • 3592
          Hi Tommy
          Looking forward to what you'll make of these. The Tamiya kit is a classic and I'vs always found adding weld seams and hull texture as part of the fun in building a model. I've never built the Dragon steel wheeled version but it should build up into a nice example of a late war Panther and give you the opportunity to paint different camouflage
          Will you be building 135 as per the box art? I only ask this as my large scale Panther, and possibly the 1/35 early G may be built to represent this particular 12SS tank.
          Looking forward to the progress
          Paul
            Hi Patrick nice to have you along fella  I've built one of the Dragon Panthers(albeit the Gunze Sangyo version) and if memory serves me right, it wasn't that bad of a build, although there was a bit of a fit issue with the two halves of the hull.
            Nice to have you along Jim, will welcome any advice and input mate
            Hi Monica, will let you know if I come across any issues with the Dragon Panther, if they turn out half as nice as any of your builds, I'll be more than happy, nice to have you along
            Hi Paul thanks for that and happy to have you along mate, not sure yet on the painting of these, a little undecided on how they are going to be painted, especially the camo scheme.
            I've got a few books out and I'm looking for a bit of inspiration, I'm sure I'll find something that catches my eye  I've also got some etch pieces, so will be adding some bits and pieces to them both, I think the tracks are going to be replaced on the Tamiya Panther, individual links will look better than the tracks supplied in the box, not a fan of the rubber band type of tracks๏ฟผ.
              • 22788
              Going to watch these Tommy ( I know nothing about these kits ).
                Nice to have you along Ian
                  These look like nice kits Tommy, looking forward to seeing what you can do with them.
                    Thanks Scott, so do I buddy
                      Made a start on the Tamiya Panther, with some photo etch being added and I decided to do away with the kits hull side track hangers, instead I fashioned my own using the kits hangers as templates.
                      I used Evergreen styrene cut to size, and added photo etch, personally I think these look better than the kit supplied parts, I also used photo etched grills and etch for the rear storage bins.
                      Other than that, it's slowly getting there, with more people to be added
                      • Pikeman
                        • Feb 2016
                        • 1312
                        Hi Tommy
                        you must like a challenge building two kits at the same time.
                        i am sure both kits are without their flaws but I am certain you will make a great job of them no matter what problems you come across.
                        it will be good to see them side by side as you progress through the build,looking forward to it.
                          I'll be following along with these Tommy.
                          • monica
                            • Oct 2013
                            • 15169
                            nice start Tommy,the hooks do look good,I like them,and the grill cover do also,make a big difference,
                            • grumpa
                              • Jan 2015
                              • 6142
