Hi all , heres my entry for this GB , the Yak 25 RV -NATO code name 'Mandrake'. Its the Amodel kit of this little seen cold war reconnaissance aircraft and looks to be a nicely moulded offering. The fit is something that ive yet to determine however!! If its anything like most Amodel kits its not exactly going to fall together! It has lovely restrained panel lines and the cockpit and wheel wells are nicely done too. Heres the sprue shots and box art , cheers tony
Yak 25 RV 'Mandrake' 1/72 Amodel
Theres only the one option in the box Ian , but they were all silver anyway. I think it was a painted silver laquer and not a nat metal finish though so I dont have to go too mad with the differently shaded panels. cheers tony
EDIT. Bugger! ive just been googling (!) and it looks like they were polished metal after all , so im in for a pain in the a**e masking job again!!Comment
It was a variation of the yak 25 flashlight intercepter joe. The flashlight had swept wings though , they basically just replaced these with the long span high aspect ratio ones to get better high altitude performance , thats why it looks a bit odd with the swept tail and straight wings like an il28Comment
Heres where I'm at with the Yak. The cockpit and main and nose wheel wells have been assembled and painted , the seat is ongoing . each wheel well was made up of about four or five pieces that all needed fettling a bit to get them together but thats just standard for a limited run kit like this and at least there were only two (bicycle type undercarriage with outriggers) Ive also glued the wings together (again needing plenty of sanding ) and started on the two engine nacelles. These have two inserts fitted in to give the intake /exhaust the right length but are going to take a lot of filling and sanding to get seamless. The instructions would have you put the front and rear compressor faces on before the insert is fitted but i left them off as they can be fitted later before the nacell is fitted to the wing . This means i have a straight through open hole which will make it easier to sand the filler with some 1200 grit wrapped round a pencil.heres the pics cheers tony
Cockpit is done , I havent gone to town on it as its a closed canopy , so just gave it a paint job and added sone rudimentary belts from tape. Now i can get the fuselage together , not forgetting the nose weight , and crack on with the engines. Cheers tony
Attached FilesComment
In amongst the detritus and general crap of my flawlessly arranged workbench is the fuselage , held together with multitudes of clamps. I put a ball bearing in the nose to ensure it sits on its nosewheel and no doubt itll need some work on the seams - these limited run kits tend to fit where they touch , and it dont touch in too many places!!!!
