Here is my one for the build just need to decide on the scheme
Rbaker's 1/35 Tamiya Jagdpanzer 38 (t) Hetzer Mittlere Produktion
I have only seen one of these tanks close up and you don't realise how small they are but as Patrick says very dangerous in the right hands. I also like the Mg on the periscope which was an inovitive idea at the time
This is going to look very special when built and painted
Lovely kit
Regards
RobertComment
Originally posted by \Nice one Richard I like the box art version do you get the paint in mask with this one ?
Unfortunately no paint mask is this one
Have a disc camo stencil and metal barrel coming from this as fancy having a go at the ambush patternComment
Some photos of where I am so far Hull halves are almost ready to join together just need to add the scopes for the main gun and the close defense machine gun, wheel rubber painted just needs to be masked to protect when airbrushingComment
Just a warning to anyone with this kit in their stash check carefully that you have been provided with all the poly caps their needs to be 4 large and 4 small poly caps this box only had 4 small caps 2 for drive sprocket 1spare and 1 for close defense machine gun had to dig in spares boxes for poly caps that would fit with a bit of modification on the gun barrel baseComment
well its funny how you do mention this Richard,
As my box was missing the poly caps,or I was thinking well were did i put them,looked,
for hrs in ever nook and carny ,but no poly caps,to be found,
so after sitting and looking at it for a bit,well the only thing,not having spares
was to fill the wheel with silicon,and let set for a day,Comment
The Hetzer is now all together just awating on the metal barrel and she will be ready for primer and paintComment
Barrel Arrived today so got it glued into place and just awaiting a coat of primer before paint
