Had this in stash & thought I would participate in my first GB here. I've built a few of these ROCO HEMTTs & only tricky part is keeping the crane flexible. Conversion instructions read well & look good so far, calling out model parts to be reused & good measurement detail.
[ATTACH]315299[/ATTACH]
Critical step 1 shows M939 chassis instead of M977, so right off the bat I see guesstimations called for as M977 chassis rail attachments & the end of chassis detail is different than shown.
[ATTACH]315300[/ATTACH]
Had to fudge cut (40mm not 44mm) so as not to destroy (fuel tank, tool box) rail attachments. Still took out 8.5mm. Much dry fitting of components (constructed model some & crane assy to assure swing clearance) before 96mm cut. Sloppy crane fit was cured by using additional model crane base part not included in kit instructions. White scabs to strengthen frame cut just visible.
[ATTACH]315301[/ATTACH]
Instructions offered no help on where to put removed rail attachments, so took best guess & cemented them & subframe/crane assy.
[ATTACH]315302[/ATTACH]
Parts cleaned up & ready for basic paint. C&Cs encouraged. PaulE
