Joe's 1/72 Lightning F2A Airfix 1/72
I used every single little stencil, two days of decal application bliss. No issues with the Airfix decals, they are great.
[ATTACH]290629[/ATTACH]
And why not just continue and get the lot done!
[ATTACH]290630[/ATTACH]
[ATTACH]290631[/ATTACH]
[ATTACH]290632[/ATTACH]
Satin varnish applied next, just a few bits and pieces to go now, navigation lights etc. I forgot about the missiles, wondered why I had a few decals left over from that vast sheet...Comment
Applying those decals are a bundle of fun, eh? I see you cross off the decals on the instructions as you apply them too.
Looking good Joe.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Canopy unmasked and cleaned up. Missiles are on the paint stand drying.
[ATTACH]290716[/ATTACH]
[ATTACH]290717[/ATTACH]Attached FilesComment
It's a very attractive scheme isn't it? I'm glad I got brave and didn't chicken out with the green scheme.Comment
They're not too bad Tony, and adhere well. I used Decalfix to enable them to settle into the recessed lines. They're quite thin. I worked the lower fuselage (some are tucked up under the high wing), from rear to front, then the same for the fuselage above the wing. Then the wing undersides, then the wing tops. After that I did the same method for the main decals. This way I didn't need to handle the model too much in areas where I had already applied decals.
Do the black lines on the upper wing before the roundels Tony. You'll enjoy the build.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
This is looking a real beauty Joe.
Makes me want to dig out a plane from the stash but I'm too busy with figures.
Not made a plastic kit in over a year.
So you used them all, every last one. None, accidentally went missing ? I'm sure the carpet monster reached up a grabbed a few of mine..............But anyway, it's looking great. For me, the Lightning is up there with a Harrier, perennial jets.Comment
