Colin's English Electric Lightning 1/32 Trumpeter
  • Bigfoot57
    • Jun 2015
    • 1103
    #16
    Just tried the pilot figure in the lightning you know where you position his hands on the stick then attach them to body to ensure correct pose
    Well something is drastically wrong here because if my pilots scale is correct and according to the box he is 1/32 he will need 6ft long arms to reach the control collumn either he's the wrong scale or the trumpeter cockpit is totally wrong see photo this pilot has no chance of reaching the stick
    Oh dear
      • 22771
      #17
      Nice work on the mod Colin
      • Bigfoot57
        • Jun 2015
        • 1103
        #18
        A bit of rough painting mainly to allow for unforseen bits being visible and just plain plastic showing I have painted as you can see the splitter assembly and cockpit mounting section along with the cockpit which after numerous searches and suggestions I have done a very dark grey on the floor with black consoles this will then be dry brushed to bring out detail then the am eduard sheet detail will be added hopefully making a reasonably good job.
        I also painted the inside of the fuselage as well at the front just in case any of that is visible through the cockpit canopy incidently anyone know what colour the inside of the wheel wells were for a Lightning F1
        Just roughly assembled the various sections for nose cockpit and fuselage just to make sure no painting missed to interior looks good to me so will now tackle ejector seat assembly and painting
        Just fitted the end ring onto the nose I can find no evidence of a gap between it and the rest of the fuselage as many people have reported maybe my extension removed it from the equation no idea anyway judge for yourselves there is a gap at the back of the cockpit of at least 12mm so maybe that's where it now dosen't quite work
        Regards
        Colin
        • Bigfoot57
          • Jun 2015
          • 1103
          #19
          Cockpit update
          Cockpit has now been painted and then drybrushed to bring out detail this is how it looks before any pe is added to the mix
          Regards
          Colin
          • flyjoe180
            • Jan 2012
            • 12433
            • Joe
            • Earth
            #20
            Nice work so far Colin, you're bashing this Trumpeter kit into shape
            • Bigfoot57
              • Jun 2015
              • 1103
              #21
              Just finished having a fight with eduard cockpit details I honestly have to say some of those parts are to me impossible to construct the throttle handles spring to mind so I ended up whiltling down a tooth pick to the correct diameter and used that instead
              One thing eduard need to do is improve on their instructions yes they show you where and what to do but they should also give you a view of the piece in place so you know you have put it in the correct orientation anyway here's the cockpit after being the application of pe it still needs a touch up to remove the roughness and bare metal but that is the cockpit finished next onto the seat
              1st part of seat making some sort of steel tube that goes across the top of the ejector seat again good old tooth pick whilted down to fit
              Regards
              Colin
              • colin m
                • 8770
                • Colin
                • Stafford, UK
                #22
                Nice to see this one coming along. I'm looking forward to the updates.
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #23
                  Latest small update just did a bit of painting of cockpit front end basically matt black to make the pe stand out and splitter inside the duct dull aluminium still got some more eduard pe to add hopefully get the cockpit seat and the fuselage all buttoned up by the weekend
                  Regards
                  Colin
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #24
                    Well I think my lightnings office is finished I found the pe side tedious and frustrating but the end result is not too shabby sorry I couldn't get a good picture to capture the cockpit properly so have included 3 from the batch I took during a dry run assembly to check part alignment and overall look
                    Regards
                    Colin
                    • flyjoe180
                      • Jan 2012
                      • 12433
                      • Joe
                      • Earth
                      #25
                      Looks good Colin. You're bashing this into shape nicely.
                      • peterairfix
                        • Jul 2012
                        • 11080
                        #26
                        I can see what you mean about the pe for the two different scales yours should have a lot detail being a bigger scale but nice kit bashing so far.
                          • 22771
                          #27
                          Cracking work so far Colin.
                          I must really get a move on and start mine. But I just can't get interested in building it.
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #28
                            Wait till you get to detailing the cockpit numerous swear words and hunting for bits of pe that ping out of the tweezers which I flattend literally with the application of a enginners ball pein hammer in the troublesome area wouldn't reccomend it only for therapeutic reasons
                            Regards
                            Colin
                              • 22771
                              #29
                              Regards
                              Colin
                              But a nice tip all the same Colin I may need to try it later.
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #30
                                Greetings folks small update and so not encroach on Peterairfix build with anymore of my stuff I have just ordered from France from a company called Musthavemodels the attached photo interesting experience as the whole website was in french anyway the 1/32 seat and eduard after market parts leaves a lot to be desired and in my opinion do not represent what a martin baker mk 4 should look like so after checking Hannants their 1/32 also required pe which looked ok but seems a lot of work compared to the 1/48 scale seat with all the detail in place I searched the internet and found a french website called www.musthavemodels.fr they do kits resin parts and a whole lot more besides so I found a 1/32 seat for a mirage IIIc which looks identical to the Hannants 1/48 only this time it's 1/32 which is what I need the pictures are 1st 1/48 Hannants 2nd 1/32 Hannants along with pe & finally the Musthavemodels 1/32 seat as you can see its the same as the Hannants 1/48
                                Regards
                                Colin
