Colin's English Electric Lightning 1/32 Trumpeter
  • Snowman
    • Oct 2014
    • 2098
    #46
    Wow what a build! Loving the detail, though you may be hating it in places....
    Keep up
    • Bigfoot57
      • Jun 2015
      • 1103
      #47
      More foiling I'm using the speed 5 folder base to flatten the foil before applying to the model then smooth it down on the model until the rivets etc appear in the foil before moving on to the next piece 1 panel at a time
      Because I didn't do any preshading as the foil would cover it in any case each individual panel is being done and the join lines will become the panel lines that people replicate on the painted models through pre shading that's the plan working so far
      3 hours later approx 1/4 of one side foiled as you can see from picture panels are now starting to appear with the demarcation lines of where I have cut them individually
      Regards
      Colin
      • Bigfoot57
        • Jun 2015
        • 1103
        #48
        Latest update another 4 hours work produced this yes there are a couple of mistakes but as this is my first attempt at foiling a model I'm really pleased with how it's turning out and one thing I do know if I do any more natural metal planes I will foil instead of paint
        Regards
        Colin
          • 22771
          #49
          Looking very nice Colin.
          • Bigfoot57
            • Jun 2015
            • 1103
            #50
            Last night's fumblings there are a couple of errors here and there but I still love the way it looks done like this one thing you do need is a good supply of blades for cutting & cotton buds for burnishing in the foil
            Regards
            Colin
            • stillp
              • 8097
              • Pete
              • Rugby
              #51
              Looks very nice. What adhesive are you using Colin?
              • Bigfoot57
                • Jun 2015
                • 1103
                #52
                Microsol foil adheasive
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #53
                  Hello everybody latest update fuselage side now complete still the other side to go most time consuming part was the nose area loads of small and odd shaped panels to conend with just the splitter ring left to do then move onto the left hand side
                  Regards
                  Colin
                    Massive undertaking there Colin. The foil is looking alright there.
                    • Steve Brodie
                      • Sep 2014
                      • 4652
                      #55
                      thats looking very cool
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #56
                        Latest update and 1st serious problem looking at the picture you can see 2 unfoiled panels this was due to tearing the foil when trimming to the panel size so there is nothing you can do except scrape them clean and redo them which is what I was doing when my glue brush decided to stick to the inside of the bottle of foil glue which then promptly tipped over spilling glue all over the table
                        So after clearing up that mess and that glue is very sticky and requires meths / white spirit to remove it and then washing you hands in hot soapy water to finish with
                        After that I decided to call it a night
                        Regards
                        Colin
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #57
                          After the previous nights disaster today and tonight have been relatively calm and straight foward the fuselage is finished with the foil apart from a couple undercarriage doors for the nosewheel assembly
                          Yes there are plenty of mistakes as this is the 1st time I have tried this method but the effect is quite good with panels taking on different subtle hues of aluminium along the length
                          Another thing that should have been done is the surface need sanding smooth for the foil but in so doing a lot of the raised detail would have been lost so I left it as it was so there you have it next I believe the foil has to be treated to prevent tarnishing and allow paint to be applied anybody know what that is would be greatful for advice on that
                          Ok next job will be the nosewheel assembly followed by a clean up and give the red a final coat and the black anti glare panel on the top in front of the cockpit
                          Regards
                          Colin
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #58
                            Daytime shot showing variation in panels and a lot of minor mustakes oh well never mind the decals should hide a number of them hopefully
                            Regards
                            Colin
                            • tr1ckey66
                              • Mar 2009
                              • 3592
                              #59
                              Well done Colin, the foil looks very convincing. If you're not completely satisfied with the result this time round I'm sure the experience will hold you in good stead the next time around. I have to confess I've never attempted this technique but I may do now.
                              I also admire the accuracy mods you made to the kit - excellent stuff.
                              I'm sure this Lightning (and let's face it who doesn't like the Lightning!) will look super cool once complete.
                              Have fun
                              Paul
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #60
                                Main wings pinstriped ready for red leading edges to be painted
                                Regards
                                Colin
