Yaks 1/72 Airfix EE lightning f2a
  • yak face
    • Jun 2009
    • 13841
    • Tony
    Hi all heres what I am now doing for this GB , having decided that I havent got enough time left to do the 1/48 version .The kit is the excellent Airfix 1/72 F2A in the starter set boxing . I got this reduced at The Range as it was missing the naff brushes , tiny tube of glue and 2 of the awful paints (these would all have been binned anyway!!) so it only cost me £4.99 ! result! As I hope to get it done before the deadline I'm not going mad with any extras so the pilot is going to get used instead of buying pe belts , so its a total OOB build. Heres the box top and sprue shots , cheers tony[ATTACH]289813[/ATTACH] [ATTACH]289814[/ATTACH] [ATTACH]289815[/ATTACH]
    Good price that matey, looks like a nice nice too.
    Have fun, John
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      Remember that fit issue with the intake trunking clearance and the inside of the fuselage halves! Joe and I had this problem.
      • yak face
        • Jun 2009
        • 13841
        • Tony
        Yes i remembered that one cheers Rick , thats the beauty of doing a GB like this , sharing our experience , cheers tony
          • 22770
          Nice one Tony.
          • colin m
            • 8755
            • Colin
            • Stafford, UK
            Same problem here, just keep sanding...................
            • yak face
              • Jun 2009
              • 13841
              • Tony
              Well i got started on this last night and the intake is one of the first things to assemble . Heeding the warnings from Rick , Joe ,Colin et al I tried the fuselage halves around this and exactly as with you guys there was an issue. Looking at it ,I reckon its a combination of the HUGE ejector pin mouldings and the actual intake being ever so slightly too wide .I used a motor tool to get rid of all six ejector pins and also took some off the intake sides. While I was at it dry fitting this assembly I also found I had to take some off the rear of the blanking plate so that the nose ring section would fit flush to the front of the fuselage . The cannon inserts are also going to need a bit of fettling to ensure a flush fit . This may make it sound like a poor kit but its nothing that anyone with more than a couple of kits under their belt couldnt handle and the rest of the detail and fit is looking excellent - after all we waited lots of years for a decent lightning in 1/72 so we should think ourselves lucky that we arent still wrestling with the old frog or matchbox kits! heres a pic of the offending pins![ATTACH]289846[/ATTACH]
              • yak face
                • Jun 2009
                • 13841
                • Tony
                Well my good mate Ian (papa 695) has very kindly sent me the spare decals from his 1/72 lightning build . This means that I can now do mine in the natural metal scheme which i wanted to do with the shelved 1/48 kit. Another plus is that the decals Ian has sent have more stencils than the starter set and other things like the canopy seals too.[ATTACH]289857[/ATTACH]
                • colin m
                  • 8755
                  • Colin
                  • Stafford, UK
                  Well that's lucky. Joe is looking for absolutely loads of extra small decals for his lightning - he can't get enough of them - at least I think he said so ?
                  • flyjoe180
                    • Jan 2012
                    • 12407
                    • Joe
                    • Earth
                    Tony, fantastic price for a lot of great Airfix plastic. Glad you can join me in the NMF finish for this one thanks to Ian.
                    Yes Colin, like I need more holes in my head.
                    • yak face
                      • Jun 2009
                      • 13841
                      • Tony
                      Well the pilot is done in a fashion, figures arent my thing really, but he'll look ok under a closed canopy. Ive got the fuselage together but it was a battle , I had to glue the bottom seam first without getting any on the intake duct . Then glue the top seam and also the intake duct and nose ring . Its been like a limited run kit so far in terms of fit , another example being the cannon inserts , they stand way too proud of the surface so had to be thinned. I took the opportunity to start the wings while the fuselage was setting and found even more problems here .There were HUGE ejector pin marks on the inner surface which were stopping the wing halves going together. Even the instrument coaming has a big ejector pin on the underside which hinders assembly so thats got to be fettled too. Its fighting me all the way but i wont be beaten! [ATTACH]290945[/ATTACH] [ATTACH]290946[/ATTACH] [ATTACH]290947[/ATTACH] [ATTACH]290948[/ATTACH] [ATTACH]290949[/ATTACH] [ATTACH]290950[/ATTACH] [ATTACH]290951[/ATTACH] [ATTACH]290952[/ATTACH]
                        See what you mean about fit problems on the intake now, but it looks like you is winning Tony.
                        Have fun, John
                        • colin m
                          • 8755
                          • Colin
                          • Stafford, UK
                          I've never seen pin marks like that. They almost look like they should be there. It does seem Airfix has taken it's eye off the ball recently with regards to quality. What a shame. Any way, at least Jeff came out alright, he looks quite at home in the cockpit.
                          • flyjoe180
                            • Jan 2012
                            • 12407
                            • Joe
                            • Earth
                            Its
                            One you get past the fuselage assembly it's pain sailing
                            Mine also had the pin marks and same issues.
                            Pilot looks good. Having just recently removed the canopy masks I can confirm you can't really see too much in the cockpit.
                              Coming along nicely! I had that problem with ejector pins when I built one of these for a mate, PIA getting in there, but, thankfully, once done, the fit is good. Have to say, i'm surprised they dont make reference to this in the instructions... it is, after all, called a "Starter Set"...
