Yes I can see what you mean Jens, Looking forward to seeing the results, lets hope there good.
Jens (Muttley) take on Dastardly and Muttley in Their Flying Machines - way outside my comfort zone... ;)
I've had some success with the mould but I'm using far too thick plasticard/styrene sheet to pick up the detail of the ribs...
Well, it was worth a try.
I could build a small jig for vacuum forming the wing instead but it's going to require a powerful vacuum pump considering the thick styrene I'm using so the easiest option is to wing it (pun intended) and shape it by hand, with heat and sanding.
I've got plenty of time to tinker with this until the Panther is done so I don't mind these little side projects to make the parts I need. In fact this is the best way to learn new stuff and not worry about the failures!Comment
