Forgot to add this little detail when doing the radio cable. Although the Hasegawa rear panel is slightly wrong behind the cockpit seat (the box section is in the wrong place) i thought i'd still add it as the wire from the aerial will need somewhere to go once fitted. So it goes into a trunking tube that then goes down into the cockpit. I used a bit of copper wire to replicate this and shall re-touch up the RLM 66 later.
AlanG's 1/32 Hasegawa Fw190 A8
Added few little bits n bobs on today. The gunsight, RF loop and drilled out the 20mm cannon barrels. I started with a 0.45mm as a pilot drill then gradually opened the barrel up with a 0.55mm then finished off with a 0.6mm. I didn't want to risk it any further than that. Here's the barrels.
Will do a few more bits tomorrow (maybe) depending on how i feel after work lolComment
Jeez i forgot just how tedious adding the little bits (aerials, pitot and wingtip lights) is just before painting can begin. Little bits that need to be done but take an age when you're chomping at the bit to get the compressor fired up
But all there now. Pre-shading can finally begin
[ATTACH]323990[/ATTACH]Attached FilesComment
Hi Al well it looks a good build to me like the way you have run the b-pipes down the under cart leg an drilled out the gun barrels spot on work I think an bean seems to like your build v-good that looking forward to more chrisComment
Started a little pre-shading tonight. Not happy with a couple of things but hey ho. That's us modellers for you. Can't wait to actually get some proper colour on this wurgerComment
That's the RLM 76 applied. Used Hannants Xtracrylix. Love the colours but imho they are a completeoop: to spray. Need to start masking for the RLM 74/75 now. Bluetac at the ready!
It doesn't show through well on the pic but in the 'flesh' there is a little demarcation where the pre-shading comes through. I don't like to do it too heavy. You can always go over it post-shading with a hint of dark grey/black in the main colour.Comment
