Bob's 2nd build and yes its a StuG. Tamiya 1/35 Ausf G plus extras
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    #31
    Originally posted by SteveH
    Hi Bob
    Looks OK, no matter how long it took!
    I do fruil tracks in batches of 10 just to stop it getting too boring, and I pin them together with brass pins hammered in with a mini toffee hammer.
    I used to do them at lunch break at work, which was over a year ago since I was last in the office!
    Its been awhile since I've had fun with a set of fruil tracks, so enjoy the mundane, it all gets you another step closer to the finish.
    Take care and have fun, just a little a day or you might feel spoiled.
    Regards
    Steve H
    Hi Steve, good to hear from you!
    Just watched a video on YT, guy there used a reversed large PE bender as a clamp and like you brass pins and toffee hammer, he did not drill at all! Might get some pins and practice on the spares?
    Thanks Steve, take care
    Originally posted by Graeme C.
    Progress is progress Bob, just do as much as you feel like, it's looking good so far. Only done friuls once, I cut a number of pieces of the wire to length & glued them in with CA, I'm sure there are better ways, but it worked for me.
    Hi Graeme, hope you are well.
    Al least a few less wheels than a Pz IV lol!!
    So Friday is drill, fit and glue pin time!
    Bob
    • Richard48
      • 1889
      • Richard
      • Clacton on Sea
      #32
      Looks mighty fine to me Stugmeister.You have more patience than me for doing them fruils.I got fed up after 3 hours doing M60 tracks by Bronco.Each link had 6 parts!!!,Sod that for a game of soldiers.
      Carry on that man
      Pip pip onk onk.
      Rich
        • 15668
        Hi Bob
        Track rack looks fine. All those wheels and the pins in the track - can't be anything but slow. Neat work.
        • Andy the Sheep
          • Apr 2019
          • 1864
          • Andrea
          • North Eastern Italy
          #34
          Made one length of metal tracks, loved the drilling, not lol. Took time as i added them one at a time added wire, then added CA. Trying to work out a way to make a length, keep it in place and then add wire quicker?? How do others do them??
          Thanks bob
          Sorry its not very fast chaps
          Bob
          [/QUOTE]
          Bob. I usually line up and join some links (15 or 20) on the rim of a small kitchen plastic chopping board using a two sided adhesive tape, then drill them and add the wire (you can cut to length the wire before or after placing it, I tried both solutions and are both good, at least to me ).
          When CA sets, I remove the obtained track from the board and start with a new score of links.
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            #35
            Carry on that man
            Pip pip onk onk.
            Rich
            Hi Rich, i agree that would drive me nuts as well!
            Originally posted by Jim R
            Hi Bob
            Cheers Jim
            Thanks bob
            Bob
            [/QUOTE]
            Hi Andy
            Sound advice, sir. Will look for some double edged tape and give it a whirl
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              #36
              Well, made a build changes and things went a bit faster:thumb2: smoother.
              So made a run and tried on the StuG and yes you guessed right, did NOT fit!!!!!!
              I picked up Fruil set ATL 02, BUT forgot to check. They are only for StuG Ausf A or A 2, these used 38cm tracks. From Ausf B to the end they used 40cm tracks with wider drive sprockets!
              Should have used ATL 04, as they are for 40cm tracks, ba**s or worse words.
              However all is not lost, now Mike has kindly made the correct gunners for my A2 i can use the tracks on that!
              My problems with things going wrong carries on:sad:
              Off to put head in oven, but its electric :thinking:
              Ordered ATL 04, happy days. After all this practice next set should only take about 30 mins lol
              • Lee Drennen
                • 7711
                #37
                Bob. Don’t give up it’s looking good and that barrel is very impressive. Take a deep breath and carry on my friend
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  #38
                  Thanks Lee, it can only get better, it better had!!
                  • boatman
                    • Nov 2018
                    • 14451
                    • christopher
                    • NORFOLK UK
                    #39
                    YEA Bob keep at it
                    chris
                      • 18891
                      Don’t sweat it Bob. I’m sure you have an A or A2 in the stash, so when you get around to them you already have half the tracks done!
                      • SteveH
                        • 1287
                        #41
                        Just what I was going to say as positive reinforcement.
                        There is always another Stug so there will always be more tracks to be built.
                        Try the ""measure twice, cut once""" mantra, to help with your mental foggyness, and perhaps reinforce that with a build log of the changes/upgrades as a tick list.
                        Enjoy the build and the better days when plastic gets cut and glued
                        Regards
                        Steve H
                        • BattleshipBob
                          • 6792
                          • Bob
                          • Cardiff
                          #42
                          Hi Tim, i have a completed A in the paintshop ( posh for garage ) but another A being bashed into a A2 hybrid, about 50% built. So the tracks will go on that nicely
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            #43
                            Regards
                            Steve H
                            Thanks Steve, i am guilty of rushing and not following the basics, really must sort this out, the wrong style of tracks says it all
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #44
                              Bummer Bob.....hope you get it sorted soon. Rick H.
                              • BattleshipBob
                                • 6792
                                • Bob
                                • Cardiff
                                #45
                                Afternoon
                                Due to a week of everything going wrong, i have gone back to basics. Spent a few hrs watching YT basic modelling vids! One of the best ideas was early xmas pressie from Julie, a DAB radio for the den, listening to classic radio does help calm the old nerves lol!
                                So back to the StuG, bought the CMK resin roof but forgot how many spares are left over in Dragon kits, had a look and found one, it has the correct countersunk screws and no Pilze! Screws were used by Miag from Feb 43 to May 44. The Tamiya roof has bolts, used from May 44 to end, also includes pilze May 44 to Oct 44. So totally wrong.
                                Roof fits ok as does the cupola
                                Next up, and i have to cut off the engine deck and replace with a resin one with the correct welds. Not looking forward to this one bit:anguished:
