S model 1/72 3.7 cm PaK 36 Auf Renault UE build (Simon T tribute group build)
    • 18926
    OK then, moving on to the hair and the hats......
    I decided to go with mid brown hair for all four. You can’t see much of it, so I didn’t see any point in spending time mixing for different hair colours. With hair, as with all other parts of the figure, you are trying to emphasise the volume of the area. You simply cannot highlight every hair, you’d go mad before you finished the figure. For this hair colour I used these.
    I paint the whole area with 872 then highlight the hair volume with 875. If there was more hair on view I would use an intermediate tone, and possibly a final highlight, but you wouldn’t see it here so I saved some time.
    At this point I decided that I needed a light and dark on my palette so I could tint and shade the colours. I used these..
    I rarely use black and white because I think they are too stark. I save them for highlights and shadow on black and white areas of figures.....
    Here they are on the palette...
    The next stage in painting is to block paint the helmet in German grey and to “frame out “ the face area with the same shade. It is far easier to paint up to an adjacent area neatly than it is to paint a fine line between the areas to delineate them. Make sure you paint the underside of the helmet up to the face, this is what makes it stand out (pop). At this time I also painted the chin strap in the same colour.
    Next up, I highlighted the middle of the chinstrap with a lighter shade of grey. I made this by adding a touch of basic flesh tone to the German grey.
    This can be seen on the palette here....
    The strap tint is the one below and left of the dark grey blob. Using flesh as a tint warms the grey slightly and differentiates it from the helmet.
    The tints above and right of this are the ones used for the helmet highlights.
    The first tint is used on the flare at the bottom and on the crown of the helmet. Remember to unload the brush first to remove excess paint, and to start the stroke where the lightest coverage is needed. You want to paint it, not flood it.
    The second tint is also used in these same areas, but covering a smaller area leaving some first tint visible between that tint and the base colour. The last, and lightest, tint is used for edge highlights and the very top of the helmet where it is horizontal and would catch and reflect the most light. To highlight edges it is easier to use the side of the brush, just touching the edge in question. You can do it with the point, but run the risk of painting into the shadow area.
    I didn’t take pictures in between the various layers as I use a wet brush and only rinsed between colours.
    Here are some shots of the figures as they are now.....
    The top figure shows the shadow generated by the initial framing out in dark grey. This makes the face and helmet pop nicely off of each other. Don’t worry about slight over painting on the collar, this will be fixed when that is painted. In the second shot the figure on the left has an olive grey base colour, but the technique is exactly the same, just mix your highlights and apply them as shown. All colours have been applied with the same number 1 brush.....
    Lastly, a useful resource for basic German uniforms, including relevant VJ paint colours, can be found here...just use the stated colour as a base and tint or shade with the light or dark paint.
    See below for images of WWII German Uniforms, including a breakdown of the clothing and equipment pictured and Vallejo paint references.
    Hope this helps, as always just ask if my Wiltshire is difficult to understand!
    • Steve Jones
      • 6615
      #137
      Really appreciate you giving us an insight into your figure work Tim. Enjoying this blog unfold. Great work all round
        • 18926
        Thanks Steve. Glad you like it.
          • 18926
          Hi all
          Not got much done recently, just trousers....
          As always, I’ve gone with a preferred colour then shaded it for the shadows and tinted it for the highlights using the light and dark that are already on the palette. Not much to work with on the standing figure, but both were under painted with the shade. The vertical surfaces and those above horizontal that catch the light were painted with the straight tint. Finally the kneeling chap has had the top of the thighs and top of the creases lightened with the highlight. The standing chap has just had front of the thighs highlighted in the same way.
          As I was painting four figures I tried to generate a little variety in the uniforms. I therefore used these colours as the basics
          I did two in fieldgrey, and one each in the other two....
          As you can see, one advantage of this approach is that you will eventually generate a wide variety of closely linked colours on the palette. These will all remain useable unless you take ages between sessions. Therefore if you have several figures to paint you can easily add variety to the figures by using whatever colour you want to use. You are not tied to one colour for all the uniforms. It increases speed considerably. Also, because they have been tinted and shaded with the same colours they will tie together visually yet will exhibit the shade variety seen in life.
          You can also use these mixes to correct any overpaint mistakes made during the more demanding equipment painting.
          Next up, I need to frame out the jackets with a dark colour and then paint them. Normally I would paint the boots next, no real reason why, I just do As these figures are not conventionally based I won’t do that. I will wait until the top part is painted and varnished so I can handle them without damage.
          As always, any questions just ask....
          • Ralph
            • Oct 2020
            • 158
            #140
            Great thread Tim :smiling3:.
              • 15734
              Hi Tim
              Very interesting. Appreciate the extra time this detailed posting takes. Little men look great.
              • Mini Me
                • Jun 2018
                • 10711
                #142
                Learning a lot here Tim....what will you use over the top coat to protect the finish?
                  • 18926
                  Thanks Ralph, appreciate it.
                    • 18926
                    Originally posted by Jim R
                    Hi Tim
                    Thanks Jim. It takes far longer than the painting, though that does slow down a little. as you get to the more detailed stuff. I’d still say no more than 15 minutes each actual painting so far....
                      • 18926
                      Hi Rick
                      As these are gaming figures they will get a top coat of Klear followed by a coat of Matt varnish. If there are bright metallics on the figure (not needed on these) I would then paint them in last to preserve the shine.
                        More great stuff Tim, thanks.
                        It certainly shows how useful a wet palette is for this kind of thing.
                          • 18926
                          Yep, a wet palette is a great tool for acrylic painting. I find it indispensable for a one-off or small batches of figures. If I was painting a larger group though (24 or more for big battalions games) I’d use a dry palette for the base colour and gradually lighten the mix.....I’d do all of one item, say the trousers, half a dozen at a time with different base colours. I’d then then mix the figures up and perhaps do the jackets In the same way.... Working that way you get variations into a unit but minimise the time spent on the painting process.
                            I know someone who wanted to paint all his 40K troops individually rather than assembly-line fashion like you describe, in essence because he fancied himself a bit of an artist. Fine, if you’ve got, say, a Space Marine army with a couple dozen figures. He, though, played Imperial Guard with tons of them :rolling:
                            Now back to our regularly scheduled programming
                            • JR
                              • May 2015
                              • 18273
                              #149
                              Thanks Tim for the tip about drying the brush, will try to remember .
                                • 18926
                                Now back to our regularly scheduled programming :smiling3:
                                Did he ever finish Jakko? I painted about 250 fifteen mil ACW rebels last year and worked out a way to get variety in while still using the “it’s Tuesday so I’m painting blue trousers” batch paint method. I prepped and mounted them in batches of 30, five to a popsicle stick, and then more or less randomly worked through with the chosen colours.
