Particularly looking forward to the painting Tim.
S model 1/72 3.7 cm PaK 36 Auf Renault UE build (Simon T tribute group build)
Hi Tim, Looking forward to the fig. painting, so lots of info if you please, as you go through the various steps........Came across this photo on the i-net (for ref. only).....made me think of your efforts here.....I guess the "Jerries" were keen on putting these anti-tank guns on anything that moved. Gave me a chuckle anyway. Cheers, Rick H.Comment
Hi Tim, Looking forward to the fig. painting, so lots of info if you please, as you go through the various steps........Came across this photo on the i-net (for ref. only).....made me think of your efforts here.....I guess the "Jerries" were keen on putting these anti-tank guns on anything that moved. Gave me a chuckle anyway. Cheers, Rick H.[ATTACH]406943[/ATTACH]Comment
Hi Tim, Looking forward to the fig. painting, so lots of info if you please, as you go through the various steps........Came across this photo on the i-net (for ref. only).....made me think of your efforts here.....I guess the "Jerries" were keen on putting these anti-tank guns on anything that moved. Gave me a chuckle anyway. Cheers, Rick H.[ATTACH=CONFIG]n1138943[/ATTACH]Comment
This makes the little Renault more useable..probably kills its power to weight ratio though....
OK, quiet at the back there, we are going to start on the, figures....
The figures have been cleaned, assembled, and primed.
Cleaning and assembly is done exactly the same as any other plastic kit. I use a 15a scalpel blade to scrape down seam lines and blemishes and finish off with fine wet and dry (400 down to 3600 grit, used wet). Assembly used Contacta or EVA liquid cement.
I always prime figures, especially these, as they will be handled in games. Priming has several advantages to me. It binds well to the figure, making the paint job more robust. It provides a good key for the top coat, and it gives an even colour for the painter to work over. I picked grey for these because WW2 colours are muted and if the paint is slightly translucent, a slight greying out of the top coat can enhance the paint job. Sometimes, for bright coloured figures, I might use white primer. However, I very rarely use black as a primer, because I find it hard to get a decent top coat colour density over it. Some painters swear by it, but I’ve only ever sworn at it.
In this case, the primer was Alclad 2 grey primer and microfiller. No real reason for this choice except I have a bottle that has been hanging around for several yearsI prefer cellulose (lacquer) based primers as I feel they adhere best, so also have Tamiya and Mr Color in stock.
The next stage for me is a black wash to highlight detail on the figure. This is liberally applied with a number 4 round brush. The function of the wash is very similar to a pin wash on armour. It highlights detail and show the discrete
areas of the figure. In my case it also makes the figure much easier to read when I’m painting. Even at this point the figure will start to come alive.
The wash is made from a 50:50 mix of these two...
The game colour wash is designed just for this sort of use, but the black has a strong pigmentation. The glaze medium therefore “thins” the wash without taking away its useful characteristics. As I understand it, glaze medium is basically colour wash without pigment. You can dilute the wash with water, but if you do you may break down the consistency of the wash, and increase its surface tension. It will not then flow like it should, and could dry blotchy.
This part is just a quick insight into my figure painting preparation. There are as many ways to do this as there are painters, but this one is timeworn and works for me. I have been doing this, or something similar, for about thirty years.
I know some of you want to see how I do faces....well, that should be tomorrow and over the weekend....
Hope it helps, and if you have any questions, just ask away....Comment
[ATTACH=CONFIG]n1139121[/ATTACH]
[ATTACH=CONFIG]n1139122[/ATTACH]
[ATTACH=CONFIG]n1139123[/ATTACH]
ATB
AndrewComment
ATB
AndrewComment
