Hi guys long time no see
I thought you might be interested in this build that I've just completed after 2 1/2 months of work
My aim was to build one of these:
Click here for Technical Data Sheet
This is a new vehicle introduced to Afghanistan in 2011 which is a combination of a Spartan hull with enhanced mine protection and a Scimitar turret. It also incorporates anti-IED ECM gear and of course the bar armour I cherish so much!
The challenge here is that the only Spartan kits in 1:35 are from Accurate Armour and they are of the old version, pre-LEP which upgraded the engine and added extra armour, so there was a LOT of scratch building to be done! I bought the AA Warrior bar armour in the mistaken belief that it would be usable to some extent. Sadly it wasn't directly but the resin brackets, nuts, bolts and connectors came in very useful.
So I started with this lot:
and with plans I'd created from various research sources
which turned out to be 8% overscale, and even then the side panels are a little too tall
The bar armour is constructed from LOTS of 1.5mm wide, 0.25 mm thick Evergreen strip, with 0.5mm brass rod as the vertical bars.
Now this build could not have happened had it not been for the wonderful source material from the Plain Military site, in particualr these two thread from 2012:
http://plain-military.proboards.com/thread/4962/qrl-sqn-cvr-mk-2
http://plain-military.proboards.com/thread/4925/scimitar-2-complete-walkaround-over
Superb
sets of photos showing pretty much everything I needed to see!
Superb
