That's fantastic Si - looks like it could take on some full-size tanks!
1/16 HENG LONG TIGER I 'HERTA' FULLY FINISHED-HONEST!
As you know, I finished this and then found some upgrade parts-being waiting for them to arrive and then fit.
Fitted: New headlamps with proper cover, armoured transmission plates-inner fronts, correct top hull vent (next to jacking block), aerial fitted in correct position and painted-old RC aerial position (rear engine middle) plugged up and painted, turret vision slits cut out. rear convoy light-painted in blue, front machine gun now has scale butterfly clamps at either side for the cover to fasten, hull periscopes fitted and a 2.4Ghz upgrade board so she now handles so much nicer with better sound.
So, here she is, finally finished!
Attached Files- 13112932_992176327534120_2232049007844204938_o.jpg (5.6 KB, 0 views)
Originally posted by \Great job si, as always, your weathering is second to none.Comment
I lied...so sorryI had to get some extras...just couldn't help it!
I have added some tiny padlocks and chain to the turret stowage bin.
I also have some S-mine throwers and lifting mushrooms on the way.
I really should source all the stuff together but this way the wife doesn't see a huge bill...I hope...I'm probably dead.
Attached FilesComment
Cheers Ken, this has been a good one to do, and it moves and shoots!Comment
