D9R Bulldozer
  • bazers
    • Oct 2013
    • 2611
    #16
    Great work ralph weathering is brill.
      Thanks for the kind words Barry .
      • yak face
        • Jun 2009
        • 13854
        • Tony
        #18
        Perfectly weathered ralph , its a real beautiful build. Absolutely first class work , cheers tony
          Thanks for the kind comments Tony .
          • monica
            • Oct 2013
            • 15169
            #20
            superb looking beastly,real like the weathering,and the mud,over all,just the grimy look,
            very well done,and the base blends in,like the idea with the reddish shade of dirt as well,
            great build this one,
              • 22771
              #21
              That is just great Ralph.
                Thanks for the kind words Monica .
                  Thanks for kind words Ian .
                  • peterairfix
                    • Jul 2012
                    • 11080
                    #24
                    Grimy dirty not to over the top just perfect lovley build
                    • Gern
                      • 9226
                      #25
                      Originally posted by SWR
                      Thanks for the kind words Dave.
                      You are correct about the tracks.
                      When I built the lengths I found them to be just a tad too long.
                      After quite a bit of thinking and test fitting this is what I came up with.
                      I glued the track(I alway's put tracks on prior to painting)to the return roller,when set I then glued the track under tension to the front roller,again when set, I glued the track to the rear roller.
                      The next thing I did was to glue the bottom of the track to the wheels,for this I coated them with Testor's cement and when about half way dry I
                      pressed the tracks together as tight as I could going from the back to the front.
                      There was a bit where the track didn't quit sit correct at the front but this would be hidden by the blade support's and covered with dirt.
                      I hope this helps.
                      Ralph.
                      Thanks for that Ralph. At least I have an approach to the track problem when I start this - however, knowing there is a problem, I've moved it back down on my 'to do' list!
                        Wow, great work and very realistically done!!! Well done Ralph.
                        • Pikeman
                          • Feb 2016
                          • 1312
                          #27
                          That is just a stunning peice of workmanship,the weathering is spot on the whole thing  looks so realistic.
                          fantastic job
                          • spanner570
                            • 15439
                            #28
                            Top work Ralph. Very, very nice.
                              Thanks for the nice comments Peter .
                                Thanks for the nice words Leo .
