Still Only a basic build and paint job, I'm currently looking into buying a few cheap 2nd hand models to test out my weathering so not to ruin my completed tanks... And once I'm happy I will start weathering all of my completed projects... But for a basic build and paint I'm happy..
1/35 M48A3 Patton
GuestTags: None
I came here expecting to see a tank marked with the Playboy logo but I’m disappointed.
Seriously, though it’s built straight from the box, you build them pretty neatly. My only real remark is that the exhaust extension should be vertical, not angled. (And as a historical remark: that thing was rarely used, probably hardly ever on a US Army tank, and even more rarely on one with field modifications like the machine gun on top of the cupola. But that’s my background in modelling Vietnam-era tanks showing through, I’m afraid)
Thanks for feedback Jakko, i tend to follow the instructions when building, hence why snorkel is attached... As for it not being straight that's a manufacturer fault then as the position it goes in is on the tilt as you can see from pic of instructions I've attached. If it wasn't really used I'm more than happy to remove it as it does look rather odd if I'm honest. As for not having playboy bunny I'm really sorry lolComment
The “problem” is that you’ve attached it so it’s perpendicular to its “base” which probably means you forced it somehow, as IIRC there’s a flat on the pin it goes onto (in all I’ve built about half a dozen of these Tamiya M48s, I think
You’ve probably already outgrown the age at which putting on those decals would have been an automatic choiceComment
Thank you, I'm going to give it a try on a 2nd hand build as to not ruin my work..... I have weathering powders from humbrol, that my wife bought as a present awhile back, are they any good do you knowComment
Jamie,
A great build, and a good idea to try out techniques. I have an old kit which I use to test on before using on my current build.Comment
[ATTACH]311428[/ATTACH]Comment
Humbrol weathering powders are good, they do the job. ( but we all have our favorites ) There's plenty of how to do videos on youtube to look at.Comment
I lovely little build Jamie. The weathering process is a minefield and will take you some time to master. Remember You Tube is your friend and you will find some wonderful help there. Good luckComment
