From my build topic here, it's now finished
When I get some more weathering practice and products I may do more work on it but it's as far as I can take it right now. Getting the wheels straight was a challenge as I already knew the suspension wasn't perfectly lined up, but using Jakko's tip of starting with the 4 corner wheels then adding the middle ones worked pretty well. I managed to snap off yet another grab handle during these shots so had the superglue out again! Antenna also got broken off at some stage so I've used a bit of wire instead.
No decals (which is probably a good thing given how bad I am with them :smiling5: ) but again, may add some later. I'm also aware that the gun is aiming far too high to be realistic, but that would required major surgery to rectify so it'll have to do.
[ATTACH]344419[/ATTACH]
[ATTACH]344420[/ATTACH]
[ATTACH]344421[/ATTACH]
[ATTACH]344422[/ATTACH]
[ATTACH]344423[/ATTACH]
[ATTACH]344424[/ATTACH]
[ATTACH]344425[/ATTACH]
Thanks again for all the help, advice and great comments in the build thread. I've broken my duck on wheely things so who knows, I may even try something with tracks soon :flushed:
