1/72 Pegasus Paper Panzer P-245-010 - Finished!
  • adt70hk
    • Sep 2019
    • 10415
    Hi all
    So this kit marks a new era for me and it's the first one I have painted using one of these new fangled airbrush thingies! I actually did the painting last year but only decaled and weathered it just before coming aboard the forum. The filter was a DIY burnt umber one and very dark brown DIY wash in relevant places. I think the filter worked well but the wash less so...........
    I chose the kit simply because as a freebie quickbuild kit it was ideal to practice on without wrecking a decent model. I would really welcome your honest opinion of what you think as it is the only way I will learn. I've also included a pre-weathering shot for comparison purposes
    As for the vehicle I knew nothing about it but one website I found had this to say about it:
    "According to 'Special Panzer Variants' by Spielberger and Doyle it is a Special Vehicle V Porsche Type 245/1. Combat Weight: 18 tons. Crew: 3, Armament 5.5cm rapid fire gun with a belt feed. Designed for AT/AAA targets with an elevation of 90 degrees. Powered by a 10 cylinder gasoline motor type 101 which produces 316 HP. Armour: Hull 60mm Front. Top speed of 65km/h. The design never went past the wooden mock-up scale model – stage of development."
    ACW as usual and please be honest!!! :worried:
    [ATTACH]357316[/ATTACH]
    Pre-weathering
    [ATTACH]357317[/ATTACH]
    Finished
    [ATTACH]357318[/ATTACH]
    [ATTACH]357319[/ATTACH]
    [ATTACH]357320[/ATTACH]
    [ATTACH]357321[/ATTACH]
    [ATTACH]357322[/ATTACH]
    • 22771
    Nice work
      Heh … I’ve seen that boxtop plenty of times, but only now with these model pics do I realise the superstructure and turret are cast parts. I find them very unappealing, I must say — nothing to do with your building and painting them, which looks good, just that the whole shape of the thing does absolutely nothing for me
      • adt70hk
        • Sep 2019
        • 10415
        Originally posted by papa 695
        Nice work
        Thanks very much!
        • adt70hk
          • Sep 2019
          • 10415
          Originally posted by Jakko
          Heh … I’ve seen that boxtop plenty of times, but only now with these model pics do I realise the superstructure and turret are cast parts. I find them very unappealing, I must say — nothing to do with your building and painting them, which looks good, just that the whole shape of the thing does absolutely nothing for me :smiling3:
          I know what you mean. As I said above it was a freebie that I had no intention of building but thought it would be good base to test my then new airbrush on.
          • Fernando N
            • 2448
            Nice one Andrew and smart to test out your new AB on a cheap kit.
            What nozzle size and paint did you use?
            • adt70hk
              • Sep 2019
              • 10415
              Thanks very much Fernando.
              The AB was a cheap Chinese one that came with the compressor I got. I've been told the needles are often around 0.4mm on these. I knew it was not going to be the best but it works ok and it gave me the chance to play around with something cheap and not risk wrecking a decent AB before I had got used to handling them.
              Paints - all acrylics. The 'dunkelgelb' was Humbrol. Brown and green was Vallejo. The filter was tiny bit of artists acrylic burnt umber thinned to almost a water consistency and worked really well in my humble opinion. The dark wash was a 50/50 mix of Revell black and dark earth. Unfortunately I didn't thin it enough but you've got start somewhere!
              Thanks again for stopping by.
              • JR
                • May 2015
                • 18273
                Andrew.
                The dark wash to me looks ok, it's in the right place, maybe a little heavy in one little spot as you mention but has the right effect.
                The more we do the hopefully then more we learn. Good start .
                • adt70hk
                  • Sep 2019
                  • 10415
                  Andrew.
                  Thanks John. It didn't quite work out as intended but I was able to correct the worst of it and as you say only practice will improve my skills.
                  • Mickc1440
                    • 4779
                    More nice work Andrew, for some reason they make me thing of egg boxes with a turret :smiling2: :smiling2:
                    • scottie3158
                      • 14208
                      • Holbeach
                      Andrew, That is a great finish. That is not a design I have ever scene before, certainly a strange little beast.
                      • adt70hk
                        • Sep 2019
                        • 10415
                        Paul, Mick
                        Thanks for taking the time to stop by and apologies for completely missing your comments and, yes, it is an old little design.
                        • Steve Jones
                          • 6615
                          Sorry to have missed this Andy. Its different and well constructed and painted. What's on the bench at the moment??
                          • adt70hk
                            • Sep 2019
                            • 10415
                            Thanks for stopping by and your support. I also see you've found what's on the bench next.
