It's growing ....
  • Gern
    • 9254
    #31
    Originally posted by minitnkr
    Some great work. There are some great unit decals available for this scale. PaulE
    Thanks Paul. You're right and markings do add a lot to these simple kits. I have bought a couple of sets of basic decals and used a few on the kits I have completed.
    However, I'm likely to only buy one of each type of vehicle available (unless there are noticeable differences such as between the T34/76 and T34/85 or a Blitz and Maultier) so having a set of specific numbers for a squadron or division would be of no great use. If I can find room for a national marking, vehicle number or some sort of division ID I'll put them on a vehicle, but ANY sort of suitable marking will do for me. The research needed to provide accurate markings for kits holds no interest for me. As long as I get German markings on German tanks, and Russian on Russian etc I'm happy.
    Yeah! I know! Total b****y amateur with no appreciation of history! Afraid I'm just lazy that way.
    • Gern
      • 9254
      #32
      Hi Dave
      The colour you need as a base is a red brown. The problem is going to be getting the consistency right.....just using dilute paint wonโ€™t work. Properly made washes don't act like pin washes on armour, they shade the creases gradually. You can make washes using Klear and paint, but it is very hit and miss, I think it is honestly easier to buy some Vallejo game colour 73204 Flesh wash. Think of it as the secret ingredient in the secret ingredient sauce that is figure painting in the small scales.....
      Lord only knows where it came from 'cos I don't remember ordering it but I found some! What do I do with it? Just splash it on all over 'enry style or do I need to do anything else to my figures first? They have been painted with acrylics and I've added a matt acrylic varnish on top.
        • 18944
        Hi Dave
        The modelling gods have smiled on you today......
        No further prep needed.
        Experiment on a few figures first. Mix the wash thoroughly. Put a couple of drops on a pallet and simply paint it all over the flesh coloured areas on the figures....I use a number 0 brush for 15mm.....and let it dry. It may look horrible at first, but wait for it to dry first....
        If the effect is not pronounced enough, use another coat of wash. If it is too pronounced, (unlikely with flesh wash) dilute the wash slightly.... Donโ€™t dilute it with water though......if you need to dilute it, I find it best to use Matt medium....
        • yak face
          • Jun 2009
          • 13870
          • Tony
          #34
          Looks like you need some ant powder dave , your bench seems to be infested !
            • 15798
            Hi Dave
            Like Tony I was reminded of ants :tongue-out3:
            Seeing the vehicle on the paint pot really brings home just how small these are.
            All credit to you.
            • adt70hk
              • Sep 2019
              • 10438
              #36
              Looking very good indeed and a great idea for a 'mini' dio. I'm a big fan of PSC too and have quite a few of their 1/72 kits - if you check out some of my recent posts you'll see what I mean! :rolling:
              Keep up the good work.
              All the best.
              • Gern
                • 9254
                #37
                Hi Dave
                Thanks Tim. I'll have a go at a couple of figures later tonight.
                • Gern
                  • 9254
                  #38
                  All the best.
                  Thanks Andy. I've seen some of your work - maybe one day I'll get that good but don't hold your breath!
                  I agree. The PSC stuff is very good quality and excellent value for money. I'm trying to find some 15mm Flames of War stuff as that looks to be about the same. Unfortunately, I've not found anyone who sells individual kits - only the box sets which are not good value for me as I only want single items.
                  • Gern
                    • 9254
                    #39
                    Lots of pictures!
                    I've already said I'm planning some sort of dio for these teeny kits. With that in mind, I've got hold of some buildings.
                    There are loads of resin cast buildings out there - many of which I consider to be extremely poorly made. I know wargamers don't necessarily need or want perfection in their scenery and I can understand that totally. However, I don't want to build a set of scenery for a wargame, I want something at least as accurate as the kits I want to put on there. I found two companies which make the kind of thing I'm looking for - I'm certain there are others - although there are some niggles with both
                    These are part of a set of Russian buildings from a company called Timecast.
ID:	1121336Click image for larger version
                    Nicely done with just a smattering of bubbles here and there. Unfortunately the church building arrived broken (Not the company's fault. My package had one corner bent in so I assume it was dropped somewhere in transit) and the joint between the roof and dome will need some filling/sanding.
                    Here's my minor problem. The figure is one of Plastic Soldier Company's 15mm range. He stands exactly 17mm tall without the base. The door he's standing in front of is also exactly 17mm tall. At 1/100 scale it should be just under 20mm. I can live with that difference - I just need to leave a bit of a gap between the figure and the building - only the pickiest of observers will notice
                    Here's a section of wall from the same company. Again, nicely moulded with minimal bubbles. No problems here as such a wall can be any height.
                    The second lot of buildings come from a company called Tiger Terrain.
ID:	1121342Click image for larger version
ID:	1121343Click image for larger version
ID:	1121344Click image for larger version
                    Again, these are beautifully moulded with even fewer bubbles.
                    These doors are only 16mm high, so again they're too small, but I can still use them as long as I leave a gap.
                    I could use both sets of buildings at each end of a dio but they don't look quite right next to each other.
                    Speaking of looking right when next to each other, the buildings from Tiger Terrain actually fit around a courtyard supplied with them. No prizes, but what do they represent?
                      • 22788
                      #40
                      Just caught up Dave, some very nice work so far. At first I thought you were planning on doing a diorama of the battle of Kursk with all the vehicles, but not sure now.
                      • Gern
                        • 9254
                        #41
                        Thanks Ian. Still only rough ideas about the dio but it won't be based on anything factual. Any relationship between the events and characters portrayed and real people and events is purely coincidental!
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #42
                          That's a tough question Dave. What do they represent?
                            • 18944
                            Hougoumont at a guess! Looks like the old Airfix Waterloo farmhouse!
                              • 18944
                              Nice buildings by the way.....
                                • 18944
                                Big error.....should have said La Haye Sainte....
