Italeri Sherman M32 ARV - "Junkyard Find"
  • wasdale32
    • 1115
    • Mark
    Hi
    no build log but I thought I'd post the completed article.
    Its the Italeri M32 from way back in 1980 - picked up from a fellow club member for a fiver. It isn't a great kit and the accuracy is doubtful but it was a good basis for the "abandoned vehicle" techniques.
    Paints are a mix of Vallejo/MIG/Tamiya and the rust is largely the real thing from "Deluxe Scenic".
    Will be mounting it on a simple base surrounded by weeds.
    Still debating whether to add some graffiti (eg peace signs) or not.
    Comments welcome.
    MarkClick image for larger version
ID:	1131232Click image for larger version
ID:	1131233Click image for larger version
ID:	1131234Click image for larger version
ID:	1131235Click image for larger version
ID:	1131236Click image for larger version
ID:	1131237Click image for larger version
ID:	1131238Click image for larger version
  • Gern
    • 9219
    That's a great piece of work Mark and it really deserves a base to pull it into context.
    • spanner570
      • 15404
      Mark, that is nice. A great piece of rusting and neglected 'junk'.
      Re. the graffiti. If it were my model, I would leave well alone and place it on a simple base. I find any sort of writing on a piece of armour, whatever, takes the eye away from the model itself. Similarly, a complicated base.
      But, as we all write on here in a similar situation - It's your model.... :thumb2:
      Whatever you decide, you have produced one excellent build.
      Ron
      • wasdale32
        • 1115
        • Mark
        Hi. After a few trials in Photoshop to get a feel for what it would look like with graffiti I've decided to leave it. As the base is not much bigger than the vehicle it would detract. If it was part of a bigger set piece with other wrecks it would work. Will post pictures of base later
        • Neil Merryweather
          • Dec 2018
          • 5189
          • London
          Great job, Mark.
          I think you are right to leave well alone with the graffiti :thumb2:
          I presume it's 1-76 /1/72 scale?
          • wasdale32
            • 1115
            • Mark
            Italeri 1:35 the very old kit #203 original 1980 boxing
              • 15704
              Hi Mark
              Very nicely done. Love the splash of colour provided by the oil drum.
              I think a few flowers on your weeds would look nice.
              • wasdale32
                • 1115
                • Mark
                A few pics of it on the (admittedly very compact) base....
                White balance a bit dodgy on a couple.
                • spanner570
                  • 15404
                  Mark, a very nice base. Just enough to keep the eye where it should be, yet still a nice addition.
                  I do like the rust, and flaking paintwork is far more pleasing than the over the top, and sometimes unnecessary chipping some modellers seem to regard as a 'Must have'.
                  Yep, a nice all round build. Well done... :thumb2:
                  Ron
                  • Gern
                    • 9219
                    The groundwork is excellent, but maybe the wall is a bit too clean? Not sure from your post and pictures whether you've completely finished though Mark ...
                    • wasdale32
                      • 1115
                      • Mark
                      Dave, thanks I tried to get a bit of detail into a small space - the base is only 12cm x 17 cm - the wall is actually a completely different base that I was just experimenting with (its one side of the FOG models "Arab gateway") - I just wanted a bit of depth.
                      Mark
                      • wasdale32
                        • 1115
                        • Mark
                        Ron
                        Cheers Ron
                        As the original had a cast hull but welded superstructure it seemed obvious that the flat rolled plates would suffer more rusting through than the hull.
                        The effect is largely down to a base coat of a darkish brown with the Deluxe product (a fine iron dust which uses a mild acid to make it oxidise) applied and allowed to rust - I then applied latex art masking fluid over the top (similar to maskol) before the top coat.
                        The latex rubs off exposing the rust underneath but unlike hairspray or chipping fluid the edges of the mask can be left which gives a more 3d layered effect which I find great for peeling paint.
                        • Del640
                          • May 2020
                          • 1151
                          Wow.
                          • Steve Jones
                            • 6615
                            A lovely project to have done Mark. Looks like you had a lot of fun with this one and pushed your weathering skills. Great to see
                            • wasdale32
                              • 1115
                              • Mark
                              Thanks for the compliments guys - it turned out OK considering I deliberately wanted to avoid spending any money on the build!
