Hobby Boss 1:35 Leopard 2A6M CAN
  • wasdale32
    • 1115
    • Mark
    Initial Afghanistan deployment before installation of Barracuda thermal camouflage.
    Built OOB with no issues with the basic kit but the bar armour could have been better engineered especially suggesting that square holes are drilled! At least the full size bar armour isn't always fitted perfectly.
    First experience of painting with Mr Hobby aqueous colours which I found sprayed really well using their own thinners.
    Weathering with home made mix of chalk pastels.
    MarkClick image for larger version
ID:	1159297Click image for larger version
ID:	1159298Click image for larger version
ID:	1159299Click image for larger version
ID:	1159300Click image for larger version
ID:	1159301Click image for larger version
ID:	1159302Click image for larger version
ID:	1159303Click image for larger version
ID:	1159304Click image for larger version
ID:	1159305Click image for larger version
ID:	1159306Click image for larger version
ID:	1159307Click image for larger version
ID:	1159308Click image for larger version
ID:	1159309Click image for larger version
  • scottie3158
    • 14201
    • Holbeach
    Mark[ATTACH=CONFIG]n1159297[/ATTACH][ATTACH=CONFIG]n1159298[/ATTACH][ATTACH=CONFIG]n1159299[/ATTACH][ATTACH=CONFIG]n1159300[/ATTACH][ATTACH=CONFIG]n1159301[/ATTACH][ATTACH=CONFIG]n1159302[/ATTACH][ATTACH=CONFIG]n1159303[/ATTACH][ATTACH=CONFIG]n1159304[/ATTACH][ATTACH=CONFIG]n1159305[/ATTACH][ATTACH=CONFIG]n1159306[/ATTACH][ATTACH=CONFIG]n1159307[/ATTACH][ATTACH=CONFIG]n1159308[/ATTACH][ATTACH=CONFIG]n1159309[/ATTACH][ATTACH=CONFIG]n1159310[/ATTACH]
    That is a cracking result. If you find a square drill let me know lol.
      • 22770
      Fantastic work, looks very good indeed.
        • 18892
        Looks excellent Mark.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Very nice Mark!!
            OK:
            • wasdale32
              • 1115
              • Mark
              Originally posted by Jakko
              OK:
              The weird cam shaped bits are interesting - Unfortunately they don't come in 2mm or 3mm square!
                • 18892
                There are Morticer bits as well….only go down to half inch though LOL….
                • dalej2014
                  • Aug 2021
                  • 507
                  Lovely build; turned out very nice indeed. Kudos.
                  • minitnkr
                    Charter Rabble member
                    • 7520
                    • Dayton, OH USA
                    Came out great Mark.
                    • PaulinKendal
                      • Jul 2021
                      • 1608
                      • Kendal
                      Been looking at your completed builds, they're all really impressive. I particularly like the way you photograph them, with that simple contrasting background. How do you set this up? it really focuses attention on the model itself.
                      • wasdale32
                        • 1115
                        • Mark
                        I use a folding light box similar to the one below - it is about a 60cm cube when assembled and has two adjustable brightness LED lighting strips - mine was from an Amazon seller. The camera is a DSLR on a tripod - I use aperture priority with a small aperture so the exposure is quite long henc the tripod. The kit came with several different backgrounds which can be arranged to curve so effectively you have an "infinite" backdrop. I find the blue or neutral grey ones are best for the armour models - the white one tends to under expose everything a bit and black can cause the camera to over expose a bit but its worth experimenting - I guess a winter camo vehicle would look good with a black backdrop.
                        • PaulinKendal
                          • Jul 2021
                          • 1608
                          • Kendal
                          Thanks for that - I think I need a lightbox!
                          • colin m
                            • 8740
                            • Colin
                            • Stafford, UK
                            A very nice finish, as mentioned above, great pictures as well.
                            • adt70hk
                              • Sep 2019
                              • 10402
                              Mark
                              Somehow missed this. That's turned out very well indeed.
                              A great effort and like the others have said great photos.
                              ATB.
