Luvin the avatar Mike. While you are looking in I have a question for you. I am struggling to find a way/a tool for doing recessed circular grooves. The primary example would be the flat end of a shell. However there are others examples now and again where there is a need to scratch precise small circular grooves. Any ideas please??
Chieftain Mk.11
Sorry for the late reply. Back in the day when we were doing cave drawings I came across some scribing templates from a company called Tritool numbers TPU-301,302 and 303. These give you circles, ovals, squares etc. And the one you will need is TPU-301 and this starts in mm from 0 (yes zero) to 9.5 dia circles. These were offered in the day when you were re-scribing all the panel lines on the Fujimi 1/72 scale Phantoms.
Amazon now do the same item £23 and call it 'Hasegawa Trytool Template Set 1 # TP01' and in it you get the same as the Tritool set.
Mike.Comment
Many thanks Mike. I will let you know how I get on. I have to scratch about 30 shell cannisters so they will be a great help. Many thanks again and happy modellingComment
Hello Steve,
Mike.Comment
The bad lands are quiet at the moment, some sort of religious thing going on so we have fireworks even today at 14.24 :rolling: Look chidren, can you see the pretty fireworks.... DUH!!!Comment
.... And if you believe that you'll believe anything!!Comment
Ahh would that be Wibble Wobble, nearly as good as Hoppity Hop , and Hippity Hop. Its the New Year on the 29th, they cold be practicing.Comment
