Sturmmorser Tiger (aka sturmtiger) - AFV Club 1:35
  • wasdale32
    • 1115
    • Mark
    Built straight from the box apart from the hull zimmerit which was done using self-adhesive aluminium plumbing tape.
    A reasonably straightforward build but care is needed fitting the casemate to the hull - some trimming required to get a good join.
    The tracks are classic soft rubber AFV Club offerings and are a tad too short - the join needs to be hidden !
    Painted with Mr Color acrylics.
Name:	IMGP3117 (Large).JPG
ID:	1199955Click image for larger version
Name:	IMGP3118 (Large).JPG
ID:	1199956Click image for larger version
Name:	IMGP3119 (Large).JPG
ID:	1199957Click image for larger version
Name:	IMGP3120 (Large).JPG
ID:	1199958Click image for larger version
Name:	IMGP3121 (Large).JPG
ID:	1199959Click image for larger version
Name:	IMGP3122 (Large).JPG
ID:	1199960Click image for larger version
Name:	IMGP3123 (Large).JPG
ID:	1199961Click image for larger version
Name:	IMGP3124 (Large).JPG
ID:	1199962Click image for larger version
Name:	IMGP3125 (Large).JPG
ID:	1199963Click image for larger version
Name:	IMGP3126 (Large).JPG
ID:	1199964Click image for larger version
Name:	IMGP3127 (Large).JPG
ID:	1199965Click image for larger version
Name:	IMGP3128 (Large).JPG
  • minitnkr
    Charter Rabble member
    • 7537
    • Dayton, OH USA
    Zim came out nice. Good camo job.
    • scottie3158
      • 14201
      • Holbeach
      Mark,
      That is a cracking result.
      • wasdale32
        • 1115
        • Mark
        Cheers - I find that a lot of home-made zimmerit is significantly overscale - original zim is only about 1 - 1.5 cm thick which equates to 0.2 - 0.3 mm thick at 1:35 so the tape gives a more scale accurate thickness & I prefer the more subtle effect
        • The Smythe Meister
          • Jan 2019
          • 6248
          Looks great to me too
          • Mark1
            • Apr 2021
            • 4156
            Nice job :thumb2:
            • Lee W
              • Feb 2014
              • 4654
              • Lee
              • Sherborne
              Nicely done Mark
              • Mini Me
                • Jun 2018
                • 10711
                Good looking "Morser" Mark. It would be an interesting subject for a small dio.
                • Mickc1440
                  • 4775
                  Lovely finish Mark, great job on the camo
                    • 15692
                    That's turned out well Mark. I've not heard of that method for zimmerit but it has certainly worked well.
                    • wasdale32
                      • 1115
                      • Mark
                      I tried it on a STUG a while back and it worked well - it can also be used to simulate anti-slip by embossing on sandpaper or straps etc - it has the added advantage over paste based zimmerit that it can be scraped off if you're unhappy.
ID:	1200020Click image for larger version
ID:	1200021Click image for larger version
                      • Mini Me
                        • Jun 2018
                        • 10711
                        I tried this years ago on wine bottle foil, I didn't get as strong an impression as you have here Mark.....how much pressure do you use and what do you back it up with under the foil that causes it to impress so distinctively?
                        • wasdale32
                          • 1115
                          • Mark
                          I just rest the aluminium tape on my cutting mat - you need to experiment with the different tools to see exactly how hard to press. The tape is quite a lot thinner than wine bottle foil and a fair bit softer than modern ( not lead ) bottle foil. To do the anti-slip pattern place the sandpaper on the mat and rub the foil on top
                          • JR
                            • May 2015
                            • 18273
                            Well The Committee thought it was damned good .
                            So you have been awarded
                            Congratulations on a stunning build Mark .
                            • Lee Drennen
                              • 7711
                              I like the Camo very clean build
