AFV Club 1/35 Centurion Mk5/2 with 105mm gun
Very nice indeed Mick - I wonder if the stripes serve the same purpose as the shield with a cross on modern German MBTs? (Whatever that is!)
SteveComment
Steve is right, they do serve the same purpose: night-driving under black-out conditions. Their purpose is so that the following vehicle can see where the one in front is, and hopefully keep sufficient distance that it wonโt bump into it but also not go so far back that it falls behind.Comment
Steve is right, they do serve the same purpose: night-driving under black-out conditions. Their purpose is so that the following vehicle can see where the one in front is, and hopefully keep sufficient distance that it wonโt bump into it but also not go so far back that it falls behind.Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
