T34 / 85
    T34 / 85
    Hi folks this is my latest build it is in 1/35 and is a zvesda T34/85, hope you like it and as usual all comments are most welcome be they good or bad.
    scott
    [ATTACH]65643.IPB[/ATTACH]
    [ATTACH]65644.IPB[/ATTACH]
    [ATTACH]65645.IPB[/ATTACH]
    [ATTACH]65646.IPB[/ATTACH]
    [ATTACH]65647.IPB[/ATTACH]
    [ATTACH]65648.IPB[/ATTACH]
    [ATTACH]65649.IPB[/ATTACH]
    [ATTACH]65650.IPB[/ATTACH]
  • takeslousyphotos
    • Apr 2013
    • 3900
    Hi Scott,
    That is a superb build ........... The weathering and beaten down effect you've achieved is really first class. :score: from me.
    I have one tiny comment........and it's a mistake I made a few times before it was pointed out to me.......... The Red Decals. They look all new and not dulled down and weathered like the rest of the superb job you've done......... Hope you don't mind my comment.
    Peter
    • PaulTRose
      • Jun 2013
      • 6455
      • Tattooine
      very nice indeed.....i take it you used the hair spray trick for the white wash?
      tried it myself for the first time last month on a Panzer IV, not as tricky as i thought it was going to be
      Per Ardua
        Very nice Scott. Cheers Derek
          peter thanks for the great comments no i certainly don't mind one bit and i have already taken care of that. beowulf it is the hair spray effect, thought it was time i gave it a try cheers for the comments no. Derek thanks mate much appreciated.
          Scott
          • geegad
            • Mar 2010
            • 2329
            superb bud lovely t-34 like the white wash effect and the weathering everywhere else is superb
              Very nice Scott. Not into tanks etc, yet, but looks a really nice model. As has been stated the stressed look is just the part. The wheels I like a lot.
              ? what is this hairspray thing. What does it do ?
              • john i am
                • Apr 2012
                • 4019
                1st class t34 weathering 10/10 just looking at it makes me feel cold :newyear:
                  Originally posted by \
                  Very nice Scott. Not into tanks etc, yet, but looks a really nice model. As has been stated the stressed look is just the part. The wheels I like a lot.? what is this hairspray thing. What does it do ?
                  Hi Laurie what you do is this after your base coat is applied seal it with one coat of Johnsons clear. once dry i applied 3 coats of hair spray one coat every 20 minutes, you apply your white wash and leave approximately 2 hours. take a cup of hot water and cut most of the bristles off an old brush, dip it in the water and scrub at the white coat, this will start to come away. Continue with this until happy.
                  Scott
                    • 18266
                    Nice one Scott
                    • takeslousyphotos
                      • Apr 2013
                      • 3900
                      Hi Laurie what you do is this after your base coat is applied seal it with one coat of Johnsons clear. once dry i applied 3 coats of hair spray one coat every 20 minutes, you apply your white wash and leave approximately 2 hours. take a cup of hot water and cut most of the bristles off an old brush, dip it in the water and scrub at the white coat, this will start to come away. Continue with this until happy.Scott
                      ............. Sloshin' all that water around 'll explain where the rust came from :fool:
                      I'll get my coat.
                        Nice one Scott!
                        The weathering is spot on! I always think, the T34 is the perfect "guy" to do a damage or weathered winter camo!!
                        And your paint work is perfect, with some interesting details!
                        Cheers. Polux
                          • 22770
                          Stunning work Scott well worth 5 stars
                            ............. Sloshin' all that water around 'll explain where the rust came from :fool:I'll get my coat.
                            For the rust i used washes of burnt scienna oil paint around the grab handles and generally here and there. it is easy to go too far here so stop working every so often and look at the kit both close up and at a distance in natural light. you will know when it is right.
                            Scott
                            • Gern
                              • 9212
                              Fabulous paint job again Scott! I think you missed a trick with the seams on the gun barrel though.
                              Gern
