1/16 Fixed position 88
  • eddiesolo
    • Jul 2013
    • 11193
    Hi guys.
    I was given this 3D print of a fixed position 88mm Flak gun from the nice gentleman who supplied the 3D reactive armour blocks for my 1/16 T-72.
    It did not print properly was scruffy with barrel issues so he let me have for free for me to 'play-about-with'.
    My first thought was that it didn't look that bad and after cleaning up would be okay, nope. While attempting to sort out the bad print lines etc it started to come apart. In the end I did it as a knocked out piece, not severe damage but fire damaged.
    The gun was primed, then airbrushed with top coat and two camo coats. Weathered using graphite, smoke, and rust. I found a metal 1/16 88 shell case and painted that.
    The base is a solid 4mm plasticard piece with me carving the concrete sections and then using the Dremel with a fine point to create some cracks. The base was airbrushed in a black and various greys, I had seen some like this base with a large semi tar like agent used in between the blocks so, replicated that. The gun was fixed by drilling and screwing into position. I then added some foliage and light dust to the base and model before sealing with a matt coat, this time through the airbrush.
    So, another set piece for our RC 'village'.
  • Neil Merryweather
    • Dec 2018
    • 5181
    • London
    Very nice
    • scottie3158
      • 14197
      • Holbeach
      Can't argue with a freebie.
      • Mini Me
        • Jun 2018
        • 10711
        Wow Si.......that turned out really nice....should add more than a bit of interest to its surroundings. :thumb2: Rick H.
        • Lee W
          • Feb 2014
          • 4654
          • Lee
          • Sherborne
          Nice one Si!
          • eddiesolo
            • Jul 2013
            • 11193
            Very nice
            Cheers Neil, it's not too bad.
            Agree Paul, always nice to get something for nothing. Also, the cost was practically nothing, just a few paints and some time, this means the stress levels drop as you are not that bothered if it goes wrong LOL.
            Thanks Rick, turned out rather good, just took it easy and took my time. Hopefully, it will have a nice spot on the battlefield.
            Originally posted by Lee W
            Nice one Si!
            Ta Lee, chuffed you like it.
