Flak 88 /18
  • andy55
    • Sep 2023
    • 325
    Flak 88 /18
    Thought I'd post this since will give someone a laugh. Getting better at the figures (only look like zombies that died yesterday, rather that a couple years ago). It's the AFV fit. Went together very well, only problems were those that I made. Ain't that always the case. The barrell and compensaters (?) Are ally which is a nice touch, the tires are rubber. The figures are Miniart and the sandbags are Tamiya.
ID:	1227871Click image for larger version
ID:	1227872Click image for larger version
ID:	1227873Click image for larger version
ID:	1227874Click image for larger version
ID:	1227875Click image for larger version
ID:	1227876Click image for larger version
    It's late evening, hence the long shadows
  • boatman
    • Nov 2018
    • 14451
    • christopher
    • NORFOLK UK
    [ATTACH=CONFIG]n1227871[/ATTACH][ATTACH=CONFIG]n1227872[/ATTACH][ATTACH=CONFIG]n1227873[/ATTACH][ATTACH=CONFIG]n1227874[/ATTACH][ATTACH=CONFIG]n1227875[/ATTACH][ATTACH=CONFIG]n1227876[/ATTACH][ATTACH=CONFIG]n1227877[/ATTACH]
    WELL Andy i think your dio looks really good as all the figures look to be doin something like they would in real so good one well done sir
    chrisb
    • Tworrs
      • Jan 2022
      • 1980
      • Garry
      • New Zealand
      Excellent Andy, you should be very proud of this diorama.
        compensaters (?)
        If you mean the two horizontal tubes that don’t elevate with the gun, then they’re the equilibrators They contain springs to balance the barrel, so it can be elevated with little effort.
        • andy55
          • Sep 2023
          • 325
          Originally posted by Jakko
          If you mean the two horizontal tubes that don’t elevate with the gun, then they’re the equilibrators :smiling3: They contain springs to balance the barrel, so it can be elevated with little effort.
          Should of remembered from the link you sent me, re the manual. Very interesting reading though hell of a lot of info.
          • adt70hk
            • Sep 2019
            • 10402
            Andy!
            Very, very nicely done indeed!
            Well done.
            • andy55
              • Sep 2023
              • 325
              chrisb
              Thanks, may revisit the figures and get some mud on them, a little too clean.
              Originally posted by adt70hk
              Andy!
              Well done.
              Thanks.
              Thanks, just need to crack painting figures, I'll get there.
              • scottie3158
                • 14201
                • Holbeach
                Andy,
                very nicely done.
                • andy55
                  • Sep 2023
                  • 325
                  Andy,
                  very nicely done.
                  Thanks
