scotties KFZ 70 and 7.62cm F.K39(r)
Paul, as a lover of all things wintery, the new snow looks so much better, I love it on the pole and signs. Spot on.Comment
RichardComment
The fault I think was all mine the flakes are large ish but I think it was due to my impatience so the individual flakes stuck to each other and not to the ground. They were from the bottle but put through a sieve. The next time it should be better.Comment
Scottie, if the ground is frozen and hard meaning its really cold, the snow would be powdery like and would be blown around like dust...seen it on National Geographic reels of the artic or scenes of the lake dash to Leningrad.
I'm sure you'll get it right next try.
RichardComment
Thank you for the compliment Paul. :flushed:
Adding snow is not as easy as it looks, scale being one important factor. As you know I use Precision Ice and Snow, now unless you plan to do several if not more snow scenes its not cheap. Doing several layers with hair spray or mount spray in between and doing it at an angle to represent driven snow is one method.
Your addition of the baking powder has certainly brought it into scale and the amount you have used looks good. Achieving a natural look as you have done, so top marks.Comment
