Trumpeter 1/35 BTM-3 High Speed Trench Digger - completed
    One of the longest continuos builds I have done, with nothing else on the bench ( no room ).
ID:	1188296Click image for larger version
ID:	1188297Click image for larger version
ID:	1188300Click image for larger version
ID:	1188305Click image for larger version
ID:	1188298Click image for larger version
ID:	1188304Click image for larger version
ID:	1188299Click image for larger version
ID:	1188301Click image for larger version
ID:	1188302Click image for larger version
    Quite a marathon. definitely not a sprint. Over 770 parts, although the tracks take up 170 off those. An engine is included, - a waste of time - there is no way you can display it and it's not complete, it has no cooling system/radiator! At times Trumpeter/HobbyBoss do this, it looks like they planned more detail, but stopped short.
    This is a model where the instructions have to be read, and understood before cutting any plastic. Some of the assemblies aren't clear until you actually have the bits in your hand & dry fitting is essential. The engineering and fit of the parts is excellent, no filler was used. The instructions are pretty good, but the complex assemblies can sometimes be vague, with a simple line drawing. The sequence of assembly can seem a little odd - adding small bits before large assemblies just invites damage. I suggest you work out your own sequence, and when you are going to paint! You can't leave it to the end - that will just make things more complicated than they already are.
    One thing I would suggest is adding location pegs to the side frames/decking. There are small pimples & shallow holes on the model. Drilling out and adding pegs will make a much more secure construction - this model is turned in your hands so many times it's easy to dislodge parts! It came apart several times & eventually CA was resorted to.
    You can assemble this with the bucket wheel assembly up or down. I did it with down, as I thought it showed the working to advantage - it does make it much longer - 290 X 90 X 90mm. With the bucket up it will be shorter, but higher.
    This is definitely a model for a more experienced modeller, the large number of parts can be offputting, when you open the box.
    I had had a dip in my mojo & this model was a real test. It can be a real challenge, but not so difficult that it ends up as landfill. I can say I really enjoyed this, but I wouldn't like to make models with this complexity on a regu[ar basis!
    The model is still available - not cheap!
    Thanks for dropping by - comments and questions welcome!
    Dave,
    That looks superb, and a credit to you and your stamina. Great result.
    Mike.
    • Steve Jones
      • 6615
      Superb work Dave. Unfortunately none of my comments came through during your build but hopefully you will receive these words of encouragement. One to be proud of my friend
        • 15817
        Well done Dave. What little sanity you had at the start must be well shredded now. It does look very good though.
          • 18958
          Great job on a complex but interesting vehicle. Nice one :thumb2:
          • Andy the Sheep
            • Apr 2019
            • 1864
            • Andrea
            • North Eastern Italy
            Dave I followed your build with great interest and the result is really nice. :thumb2:
            Considering the efforts you made and the long struggle with a very complex kit, I hope you'll appreciate this small award. :tongue-out3:
            I used to give it at work to humorously reward those who managed to successfully complete complex and apparently never ending projects.
            It is not intended to compete with the most serious and well known "The Dog" award, of course.
            Last but not least: the kit is a earth digger: cannot see how it could end as a landfiller....:smiling5:
            Andrea
            • simontie
              • Jan 2010
              • 1506
              Looks amazing
              Why is common sense not so common?
              • Valeron
                • Jan 2022
                • 950
                • Mike
                • St Albans
                Excellent work Dave. The finish is excellent and you've don3 justice to what looks like a complicated model.
                A really interestingly choice of a model in the first place too.
                • AlanG
                  • 6296
                  They were probably waiting to be approved by a moderator/admin. Joys of not being a paid subscriber/supporter to the forum. You have to wait until someone decides and approves your posts. It could be quick, might take quite a few hours or a day. If you pay up..... no waiting :smiling3:
                    That looks proper impressive. Good choice to build it with the digger deployed, IMHO โ€” with it sitting on top of the vehicle, it would be far less clear what all of that kit is supposed to be/do, while like this it should be obvious to just about anyone.
                    • Nicko
                      • Apr 2019
                      • 1454
                      • Nick
                      • East Anglia
                      Great work Dave, and what a monster!
                      I don't think I'd want to exit the cab while all those chains are flailing around.....
                      Nick
                      • stillp
                        • 8106
                        • Pete
                        • Rugby
                        Very well done Dave!
                          • 18272
                          That is a curious beast that only it's mother could love. Well done Sir you pulled it off brilliantly.
                          How did they prevent the spoil, going back in the ditch?
                            The dirt was flung out to either side by two powered rotors ( garden swing seat thingie )
                            Doesn't answer the question of how the spoil was removed if the soil was dry & sandy - probably another of the limitations of this thing!
                            • outrunner
                              • Apr 2019
                              • 2420
                              Great build Dave, only hope I can do mine as well when I gather the courage to start it.
                              Andy.
