Winter camo
    Cheers mate! Fingers crossed
      If you want winter camo there Alan try stippling the models paintwork with maskol then leave it to dry, once dry matt white 30% mix to a 70% mix thinner. Set the airbrush to 10 psi then spray the whole vehicle, build the layers up in some places and thinner in areas where you get a lot of crew traffic. Once dry remove the dried maskol and rub the edges down with a soft tooth brush.
      scott
      • Alan 45
        • Nov 2012
        • 9833
        #18
        Originally posted by \
        If you want winter camo there Alan try stippling the models paintwork with maskol then leave it to dry, once dry matt white 30% mix to a 70% mix thinner. Set the airbrush to 10 psi then spray the whole vehicle, build the layers up in some places and thinner in areas where you get a lot of crew traffic. Once dry remove the dried maskol and rub the edges down with a soft tooth brush.scott
        Cheers Scott only thing is I brush paint but I use maskol for chipping effects with varying results so that might work with brush painting so thanks for the advice mate
        • Alan 45
          • Nov 2012
          • 9833
          #19
          This is what I've done so far [ATTACH]89602.IPB[/ATTACH]
          [ATTACH]89603.IPB[/ATTACH]
          I'm relatively pleased so far for such a small build
            Wooooow! You nailed it Alan!!!
            Magnificent, I like it a lot!!
            My suggestion: you should add a very soft green wash, you will have a nice, dirt and weathered camo
            • Alan 45
              • Nov 2012
              • 9833
              #21
              Well I wasn't expecting that sort of high praise and especially from your good self Polux
              I thought I might of got a looks good or not bad sort of thing so I'm quite surprised and I'm very grateful thanks mate
              And thanks for the tit about the wash
                AAAhhh it's a puma I thought I recognised it by number, sweet job so far dude.
                scott
                • Alan 45
                  • Nov 2012
                  • 9833
                  #23
                  That's it now I tried to remember it's nickname but couldn't thanks for the kid words mate
                    There isn't any winter camo equal Alan, your one looks spot on mate, belive me! It only need some washes, no more
                    • Alan 45
                      • Nov 2012
                      • 9833
                      #25
                      That's very true , I tried to make it look like it was just splashed over the top of the original paint scheme and the oil paint really worked , next is a king tiger in 1/76 scale with a bit of chipping on the edges same scale as this but it's a bigger tank
                        That looks good Alan! I've been wondering about the best way to achieve a chipped winter camo effect in 1/72 since you started this thread.
                        • Alan 45
                          • Nov 2012
                          • 9833
                          #27
                          Patrick I find maskol or similar works very well on edges not so good on flat surfaces though
                          I'm pleased you like it , I'm getting to like brail scale
                            Alan I hate Maskol! I tried it on a 1/35 King Tiger to get a hard-edged 3 colour camo scheme & it went terribly wrong! Probably as much my ham-fistedness as anything!
                            What I've been mulling over is whether the technique for creating a worn / chipped winter camo in 1/35 would work when scaled down to 1/72.
                            When I get round to doing my Nashorn I might try something different ...
                            • Alan 45
                              • Nov 2012
                              • 9833
                              #29
                              Alan I hate Maskol! I tried it on a 1/35 King Tiger to get a hard-edged 3 colour camo scheme & it went terribly wrong! Probably as much my ham-fistedness as anything!What I've been mulling over is whether the technique for creating a worn / chipped winter camo in 1/35 would work when scaled down to 1/72.
                              I must admit I haven't tried it on a brail scale kit I first tried it on my sd kfz 250/1 and it worked a treat on corners and edges , I think for small scale you might get away with painting the edges and corners it might work on a small scale
                                True, but I'm thinking of spraying a light coat of off-white & then dragging a brush moistened with thinner to give it more of a look as if rain has washed away the whitewash.
