Tank track sag ?
  • Alan 45
    • Nov 2012
    • 9833
    Tank track sag ?
    is there an easy way to do the sag on tank tracks ?
    Ive spent most of the night doing this with various glues , it's done it but very messy in places which I can get away with by passing it of as mud but if I want to do a clean build this will pose a problem and I'd rather not spend a night trying to get the glue to stick so any quicker cleaner way would be much appreciated
    This is my attept [ATTACH]105722.IPB[/ATTACH]
  • Lee W
    • Feb 2014
    • 4655
    • Lee
    • Sherborne
    Alan,
    If you're using rubber band tracks, I used to put thickish wire (florist), melting through the hull and on top of the track, low enough to give sag but not over the top to look ridiculous, this is then hidden by weathering, hope this helps?
    If it's individual links...patients...that's why I don't bother with them!!! Lol
    Lee
    • monica
      • Oct 2013
      • 15169
      see your point hear Alan,
      as said fine if muddy,but for clean not at all,
      I do think that Aaron uses pin things from the inside hull to hold the tracks down and in place,
      maybe he will see this one to help out,
        Sag with rubber band tracks is very difficult Alan.
        The only way that I've managed it is by tying the track to each idler wheel with monofilament line, doing each one in turn. It works, but it's a fiddly job!
          I can offer two ways Alan. My way is like Aaron's in which I will use a small hand drill used for electronic boards and make holes from the inside of the hull and use pins to hold down the tracks. The other way is grumpa's trick which is to "rough up" the tracks on the inside by scratching with a razor blade and use a mixture of standard model glue and liquid plastistruct glue. Hope this helps Alan.
          • Alan 45
            • Nov 2012
            • 9833
            Thanks guys I appreciate the help , I think I'll go the drilling way it seems the easiest way
            Thanks for you help
            • aaron
              • Oct 2011
              • 2019
              I use drawing pins from the inside of the hull.
              • grumpa
                • Jan 2015
                • 6142
                Stuck myself with a pin once, now I'm a Pino-phobic
                  What I tend to do with mine Alan is I use 5minute epoxy resin a little added to the top of the guide wheels and the track, then I put cotton buds on the track sections you want to sag and leave them there till it dries, and it dries clear and you only need a small amount. I allow 2hrs till it cures then slowly remove the cotton buds then do the same on the other side, it is 4 hrs of literaly watching glue dry but it is worth the effort.
                  scott
                  • Alan 45
                    • Nov 2012
                    • 9833
                    scott
                    Cheers Scott ive been thinking of weighing the tracks down but would cotton wool bud be heavy enough or have I not understood properly?
                      Hi Alan yes it would because you would be jamming them in between the fender sections that run over the top of the track and the track itself so no weight needed.
                      scott
                      • Alan 45
                        • Nov 2012
                        • 9833
                        scott
                        Gotcha ive done mine soon as ive added the track , cheers Scott I appreciate it
                          No problem, and the track looks nice very natural.
                          scott
