First time doing rubber tracks
    Doing a Tamiya german halftrack and it's the first time doing rubber tracks was just wondering will poly cement work on them or so you have to use a different glue?
  • peterairfix
    • Jul 2012
    • 11077
    Poly cement won't work well I always go for superglue
      Cheers mate that's all I needed to know cheers. Looks like I'll be sticking my fingers together later
        That's not entirely correct since the newer Tamiya kits happily bonds with cement, and so does many other makes of "rubber band" tracks. Older ones certainly doesn't work at all, but I only use cement on all of my such tracks. If you don't want to try or doesn't trust your cement, CA glue is your friend!
        I can't say exactly when these tracks became glue-able with cement but Tamiya post 2002 for sure.
        It is however easier to use CA glue since it sets much faster.
