I like this a lot. Thankyou for the picture..it lets me visualize what I want to do. I think overall I'll incorporate that with some kind of bazooka damage above the wheel around the engine. When I start working on it I'll send some picture so you can see how it's coming along
Armor affects on halftrack
Glad it helps, I look forward to seeing what you come up with.Comment
The small holes in the front plate, between the big ones, are probably from Bazooka hits (the big ones look like 75–76 mm rounds to me).
On a lightly armoured vehicle like an Sd.Kfz. 251, it wouldn’t be much different, though a hit near the wheel would probably also rip off the mudguard, or at least seriously bend it out of shape, as that was only sheet steel and a Bazooka round explodes when it hits something. It is likely to start a fire as well, given that a side-on hit near the wheel probably goes into the engine, may damage fuel lines, etc. Fires on models, though, are most easily represented by painting the model as having rusted in the whole area affected by the fire. If rubber tyres are in a fire, they disintegrate into a whitish powder, so the 251 would probably have a bare wheel rim on at least one side, and may have sagged through it suspension on that side too because fire weakens springs.Comment
The Bazooka fired a HEAT (high-explosive, anti-tank) round, and when those hit armour plate they tend to leave just a small hole — as in the thickness of a finger or so — with scorch marks around it. Take a look at this Tiger II:
-JoeComment
Well, doing burnt out or demolished vehicle can be fun and isn't that hard really. Try to look at real life photographs and just try it out. Don't be afraid I'd say. Impact marks I tend to do by heating a drill bit and push it into the plastic, repeat if necessary. And spare etch and plasticard pieces for the inside can simulate a wrecked interior for instance.
Small example of a burnt out T-62 I did a couple of years
[ATTACH]299041[/ATTACH]
I was quite afraid at first but I just went on as I tried, if I failed I failed, luckily it was alright. Most importantly: have fun trying to ^^
CheersAttached FilesComment
Okay you guys have all given very useful information. Mind you I'm relatively new at modeling and any effects on the vehicles. Regarding the holes of where any type of round hit the vehicle, how would I do that. Drill? Heated pin? I have no knowledge of how to do it
-Thankyou, JoeComment
-JoeComment
