A little help please if poss
  • David Lovell
    • 2186
    Ah the stash looking for a new 1/72 project I came across a thunder models US army tractor took me a while to work out where it came from ,then remembered said kit was purchased at Telford a couple of shows ago ,1/35 not really my bag but this was small and perfectly formed so worth stashing. So question is what colour primer would have been used before spraying with olive ,I quite fancy doing this one but using the old chipping fluid hense the question, haven't worked in this scale for years so could be interesting thanks Dave.
  • Steve Jones
    • 6615
    Here are some links that may help
    Hey, anyone know what primer was used on US AFVs in WWII? Got alot of US stuf to get finished and need info. I have read conflicting reports, I.E. Red Oxide primer or Zinc Chromate Yellow or Zinc Chromate Green… Need to know for “chipped paint” effect. Tom
    Does anyone know what the color of pimer was for tanks of the different contries in wwII? I would like to know all of them for reference but I am working on a French FT-17 and want to have some of the paint worn off showing the primer and bear metal. What is the color of the primer?
    Okay I don't know if it has been asked before. I can not find it. But what color were American tanks primed in. Thanks Cheers Jeff
    It looks like a really neat kit. I hope you show us some pictures of the build. Good luck
    • David Lovell
      • 2186
      Steve old friend many thanks looks to be bit of a split decision quite like the idea of the paler olive primer ,so my old adage of if it looks right go with it ,thoes whom it rubs up the wrong way need not reply (they know who they are). Yep only the avatar has changed still same old lazy bloke many many thanks for the donky work will try and get a build bloggy up and running asap. Dave
