Tamiya Panzer IV rear wheel trouble...
  • JR
    • May 2015
    • 18273
    #16
    Originally posted by Xarathustra
    :smiling::smiling:
    Thanks John...I'm not 100% confident it'll be a complete cure, but it will hopefully be better than what I was fiddling around with this afternoon!
    Believe me...there were a few moments this afternoon when it was A) going to be trashed, or B) turned into a diorama wreck of some sort*
    This model has been a real struggle at times, but it's my first one in years, so I just have to (try to) take a deep breath, walk away from it for a while, and look on it as a learning process...and it's certainly been that!
    Oh, and don't even talk to me about spraying! :flushed::smiling:
    * option "B" is always a good one to fall back on :smirk:
    George.
    Nothing is worse than attempting what looked to be a simple thing and then it descends in to "I wish I'd never started this " I had problems with some top wheels, glued them on as instructed, went to fit the tracks and the blo**y wheels fell off. In the end I used thick wire drilled through and ca' d them. How come other people don't appear to have problems :smiling:
    John.
      In my experience, often the best way to solve that is to first try to persevere, and if that also leads to frustration, give up and build another model — you can always come back to the first one later on, when you think you’ve found a way to solve its problems. Insisting on finishing a model that only makes you frustrated is likely a form of the sunk cost fallacy. It’s much better to go do something that you do enjoy, than to stick with something you seriously don’t.
      • Jim F
        • Feb 2015
        • 317
        #18
        Hi George
        I'm pleased that you have managed to resolve the issue:thumb2::thumb2::hungry::hungry:
        regards Jim
          The (super glue) appears to have held! Stupidly tight tracks now on & awaiting some kind of melting process to get them to hold together...I’ll see if that works...
          [ATTACH]320219[/ATTACH]
          • stillp
            • 8093
            • Pete
            • Rugby
            #20
            Looking good!
              Those old Tamiya kits are all like that, again because of motorisation. On the real Pz.Kpfw. IV there was often a bit of sag between the return rollers, but it’s not something you’ll be able to model easily with these.
              It should — make sure the pins are all the way through the holes and press a heated screwdriver onto them to get a nicely riveted track
