Sd.kfz. 254 - Saurer wheeled/tracked armoured car
    I'm considering building this shortly:-Click image for larger version
Name:	hobby boss 254.jpg
    I'm thinking of showing it on its' wheels, as the boxart. The question is, why do the tracks not sag? I would have thought that the weight of the track would make it drop away from the road wheels. It doesn't, as any pictures show ( reference & discussion only )Click image for larger version
Name:	reference saurer.jpg
    Were there straps that held the tracks up, or was the tension of the suspension/idlers enough to keep them tight?
    It's not going to make any difference to the model, but I'm curious.
    Anyone any thoughts, ideas?
    If I had to guess, Iโ€™d say that the roadwheels (the ones in the track, not the pneumatic ones) get pushed down by their springs because theyโ€™re not supporting the weight of the vehicle, which leads the front and rear roadwheels to pull the track tight around the wheels.
      Jakko,
      yes, that's my thoughts as well. I wonder how it went from tracks to wheels - powered jacks, manual wind down? - I've seen pictures on tracks, and on wheels,but not the transition
      • Mikerf
        • 61
        I've always thought that the steering on the road wheels must be limited by the track mechanism. There doesn't appear to be much room to pull a tight turn.
          Michael,
          The front ( rubber ) road wheels have a wider track than the rear pair, giving some clearance for steering..................
          • Mikerf
            • 61
            With the emphasis on 'some', I think.
              I would expect the front and rear bogies to be angled, not level, because of the track tension, but as theyโ€™re obscured by the pneumatic wheels itโ€™s difficult to tell whether they are. The middle bogie would be level, though: if the second and next-to-last roadwheels get pushed down further than the first and last, the wheels in the middle have more room, and because theyโ€™re on a common spring, both would get pushed down equally. Probably only far enough to just rest on the track without deforming it.
              Iโ€™m not sure about that either. Thereโ€™s a large bar connecting the lower suspension arms on each side of the hull, but I suspect those to be torsion bar springs rather than part of a mechanism to crank the arms up and down.
                Hi Dave have you seen this one Sd.Kfz.245 mit Kran (crane truck).
                [ATTACH=CONFIG]n[/ATTACH]
                Pete.
                • JR
                  • May 2015
                  • 18273
                  Dave.
                  Well what ever the thoughtS on the tracks/wheels I ve never seen this before so will pull up a seat.
                  Russians had a tank BT 5 that could run on wheels, once the tracks were removed , the front wheels were able to turn for steering.
                  John.
                    John,
                    this is high in the 'to make' pile, but not at the top! - I'll start a proper blog for it - there's the starter set GB beginning on the !st April, and I want to build one of my stalled build TKS tankettes, as well.
                    • Gary MacKenzie
                      SMF Supporter
                      • 1057
                      • Gary
                      • Forres , Moray , Scotland
Name:	Saurer_SdKfz 254_1.jpg
                      Photo for discussion purposes only.
                      Shows steering at work
                      • Mikerf
                        • 61
                        Well, that's more than I thought but still not much lock. Wouldn't like to try a 3 point turn in that
                        • Mikerf
                          • 61
                          I notice that the Notek doesn't appear in any of the pictures.
                            • Mikerf
                              • 61
                              Well, that's me proved wrong again. Interesting that it's in a different position from the box art.
