Cromwell Cruiser 1/76
    Bought another tank. It’s a 1/76 scale Cromwell Cruiser Tank made by Airfix.
    [ATTACH=CONFIG]n[/ATTACH]
    Not built that one, but I think it’s pretty old, so expect fit problems If you want a really nice Cromwell in 1/72, by the way, try the Revell kit.
    (Also, there’s a separate thread for latest acquisitions )
    • Mickc1440
      • 4775
      I picked the kit up from a charity shop, it's a great little model and goes together very nicely.
        Originally posted by Jakko
        Not built that one, but I think it’s pretty old, so expect fit problems :smiling3: If you want a really nice Cromwell in 1/72, by the way, try the Revell kit.
        (Also, there’s a separate thread for latest acquisitions:smiling3
        Hi Jakko I’m still finding my way around the forum. If the mods would like to move this thread to the appropriate place that’s no problem. Thanks for your comments Jakko as they help a newbie like me. :thumb2:
          Hi Mick thanks for the helpful comments.
          • stillp
            • 8086
            • Pete
            • Rugby
            I built one of these - build thread is in the little armour GB if you want to have a look. Biggest problem was that some of the turret panels were warped.
            • scottie3158
              • 14197
              • Holbeach
              Kevin,
              Welcome aboard, looking forward to watching this come together.
              • PaulTRose
                • Jun 2013
                • 6446
                • Tattooine
                actually its a new tool kit......came out in 2011
                still has some fit issues, the small side skirty bits were what i had problems with
                Per Ardua
                • BattleshipBob
                  • 6785
                  • Bob
                  • Cardiff
                  Never built one but not expensive and good for practice
                    Kevin,
                    Thanks Scottie I’m sure you will see once I start the build.
                      Thanks Beowulf for the information and pointing out the skirty bits.
                      • stillp
                        • 8086
                        • Pete
                        • Rugby
                        Another tip - the instructions tell you to put the suspension and tracks on early, but painting is a lot easier if you leave them off until the end.
                          • 18882
                          Hi Kevin, I’ve made this as well, went together no problem at all...Pete and I agree on the wheels and tracks as well. They are easier to paint off the model, but putting the skirts on is then a little tricky as you will probably have painted the body. Just takes a little touching up if you get glue spots.
                            Thanks guys for the heads up, especially when you have built this model.
                              I received my Cromwell cruiser tank model. When I opened the box there were no decals or build instructions. Managed to contact the place I purchased the model from.:sad:
