88 mm flak,
  • shovelhead 1977
    • Feb 2019
    • 263
    88 mm flak,
    hello everyone, just wondering if anyone has built the dragon 1/35 scale 88mm flak gun, if anyone has are there any problems or any thing to look out for ? building it for someone else so I don't want to make any mistakes [ or make a mess of it ! ] will probably start it once the Harley is done as he's not in any rush for it. any comments appreciated thanks
    • 18259
    I moved it to this section as it was in the wrong one. A far better chance of someone swing it here.
      Ray,
      I made this quite a few years ago - I can't remember any problems with the model itself - but I CAN remember struggling with the instructions, with regard to which bits to add/swap/leave off for a particular barrel - Dragon are not noted for their paperwork, and this one lived up to that
      Good Luck - Dave
      • Steve Jones
        • 6615
        Here are some links that may be of help to you Raymond
        HERE
        HERE
        HERE
        HERE
          As there are several boxings, this is the one I madeClick image for larger version
Name:	dragon 88mm flak.jpg
          • shovelhead 1977
            • Feb 2019
            • 263
            Ray,
            Good Luck - Dave
            Ray,
            Good Luck - Dave
            ok thanks ian
            • shovelhead 1977
              • Feb 2019
              • 263
              Ray,
              Good Luck - Dave
              been trying to work out the instructions, as you say they arent very clear on what goes where
              • shovelhead 1977
                • Feb 2019
                • 263
                HERE
                HERE
                HERE
                HERE
                [/QUOTEexcellent, thanks very much, most helpful
                • shovelhead 1977
                  • Feb 2019
                  • 263
                  HERE
                  HERE
                  HERE
                  HERE
                  great thanks, should be very helpful
                  • Mini Me
                    • Jun 2018
                    • 10711
                    Good luck Raymond, I hope you post your progress as you build this 88.
                    Rick H.
                    • AlanG
                      • 6296
                      Have to admit i love the 88mm Flak 36/37/41. I've always want to build one and do a dio for it. I shall be pulling up a chair for the build
                        Not the 8.8 cm FlaK 18, then?
                        • Gauge1TrainsDK
                          • Mar 2017
                          • 407
                          I am actually building the Dragon 6287 during these months, because this copy was without bags for the sprues. So I thought I'd better get it done before damage happens!
                          So far I am only up to step 5, and had no problems. Doing the 37mm version, wheeled, transport mode.
                          Have not decided on the paint scheme yet, but I really love the extras that come with this 2005 Dragon kit :smiling4:
                            Do you mean the 8,8 cm FlaK 37 when you say the 37 mm version?
                            • Gauge1TrainsDK
                              • Mar 2017
                              • 407
                              Yes. It's probably just called Flak 37, since it is of course 88 mm.
                              Dragon model kit in scale 1:35, 6287 is a rebox released in 2005 | Contents, Previews, Reviews, History + Marketplace | 8.8 cm FlaK | EAN: 089195862877
