I'm thinking of adding Zimmerit to my StuG IV for the group build. I dug out my Tamiya rake from the bottom of the toolbox..............and discovered why it was at the bottom of the box! I experimented & couldn't get it to look anything that I liked. I thought of Eduard PE, but that looks too flat to my eyes, as does the transfer sheets from Meng etc.
I eventually bought this.................. from the tool section of Trumpeter
What you get is 5 flat packed applicators, ( 3 stamps & 2 rollers )
Each one has a handle of styrene, and the head looks like ABS - the rollers have a metal insert, but look pretty flimsy..............
All 5 assembled
There seem to be 2 stamps & 1 roller of a small groove & one each of a larger size ( 1/72 & 1/35? )
I decided on a little trial, to see which putty in my box worked best - I had AK putty, Revell Plasto & Perfect Plastic Putty.
I spread out a thin layer of each on 1mm plastic card, then attempted to use the stamps & rollers on each.
The AK putty & PPP were not a success! The roller skidded, rather than rolled, and both rollers & stamps clogged with filler pretty quickly.
The Revell Plasto worked the best of all, even though it eventually clogged the ridges
It's a matter of how thick you have to put the putty on, and how long it is workeable - both of which I'll find out by trial and error!
I have seen a gentleman on YouTube using these tools, and he appeared to sprinkle the surface of the putty with powder - it could have been talcum powder, or even flour, but as it was in Chinese, I couldn't say! Anyway, it seemed to prevent putty pick up & he did the turret side of a Tiger in about 2 minutes! A bit more experimentation needed!
All 5 assembled
