Rust
  • stillp
    • 8090
    • Pete
    • Rugby
    #31
    Originally posted by GerryW
    I'd guess that the factories would 'dip' the vehicles as it's the quickest way to get paint on, which would leave a fairly thick coat of paint on them (and certainly not labour intensive) - weren't the car manufacturers still dipping car bodies up until the '60s/70s?
    A bit more difficult with an armoured vehicle though!
    • GerryW
      • Feb 2021
      • 1757
      #32
      If the factory was running a production line with overhead gantries - not a problem to put a dip in the line and a bank of heat lamps just afterwards as driers.
        • 18892
        Yes, but they are not a body which is then added to a chassis.......they are built around a hull box....if you dipped it you would dip the running gear as well......
        • CarolsHusband
          • Feb 2021
          • 474
          #34
          That's how they paint submarines though, right ?
            • 18892
            Perhaps, but not in water soluble paint.....
              The need to start building Tiger tanks during WW2 saw Germany adapting existing factories for manufactoring various parts of the machine.
              Takt 9 [the final assembly station] saw final painting in red oxide primer and the prescribed base coat, either Panzer Grey or later Dunkelgelb.
              • JR
                • May 2015
                • 18273
                #37
                Paint was applied by spray from what I can find, though expect that some castings may have been dipped. From 1943 German Armour was sprayed yellow, then painted either by hand or as some film shows camo sprayed in the field .
                Russian armour was factory sprayed, winter wash like the Germans painted in the field.
                Like Tim says I can't imagine dipping a massive hull.
                  Also consider this: towards the end of the war, German tanks used the red primer as one of the camouflage colours, rather than overpainting it completely with dark yellow and then adding red-brown over it. The only reason for doing this was paint shortage — at which point, having a swimming-pool-sized tub of paint for dipping tank hulls into, is somewhat unlikely
                  • minitnkr
                    Charter Rabble member
                    • 7520
                    • Dayton, OH USA
                    #39
                    Red oxide primer was pretty serious stuff back in the day. I remember an older brother painting a 53 Oldsmobile in red oxide with a brush, block sanding it smooth & Turtle waxing it. This was after taking all the chrome trim off & filling all the holes w/bondo. The car went through six road salt filled winters before being junked after a rollover. No rust was ever evident.
                    • Airborne01
                      • Mar 2021
                      • 3963
                      • Steve
                      • Essex
                      #40
                      Red primer is part of German engineering standard practice - even today!
                      • CarolsHusband
                        • Feb 2021
                        • 474
                        #41
                        Used to be "red lead" ( lead tetroxide) until the 90'S, and it wasn't the healthiest stuff to use. Though it wasn't actually banned most manufacturers now use iron oxide in red primer instead.
                        • minitnkr
                          • 7520
                          • Dayton, OH USA
                          #42
                          That's the stuff. Remember lots of paint was lead based. Used lots of turpentine.
                          • wasdale32
                            • 1115
                            • Mark
                            #43
                            All bare metal ( with the possible exception of gold ) will oxidise when exposed to the air - the rate of oxidation also depends on the level of moisture and acidity in the air. "Rust" is the specific term used to refer to IRON oxide. Iron containing materials such as cast iron and steel will "rust" but at very different rates.
                            Even high quality steel products will form surface rust quite quickly - just look at the disc brakes of a car that has been standing unused outdoors for a few days but this will be bright orange surface rust which easily rubs off. Cast iron ( or some cast steel ) products will oxidise to a dark brown colour over a longer period of time - just take a look at drain grids or manhole covers in the street - this colouration doesn't easily rub off it just polishes.
                            Non-ferrous metals such as aluminium will oxidise differently - aluminium tends to become a dark grey, zinc and its alloys often form a light grey or white oxide, copper and brass tarnish to a darker colour and sometimes form a green "verdigris" colouration (but this takes a significant amount of time).
                            Often poorly finished, relatively thin, mild steel such as that on fenders or stowage boxes will show signs of rusting under paint layers - often due to the fact that paint has been applied over existing damage without adequate surface prep.
                            Tracks are often a tricky thing to get right - the closest most of us get to them is when we see museum exhibits or "gate guards"/monuments which usually do show deep oxidation ( light or even dark brown colouring ) with little or no abrasion visible. Working vehicles usually show some bare metal (depending on the track type) but this depends on the surface they are operating on.
                            • Graeme C.
                              • 1597
                              • Graeme
                              • UK
                              #44
                              I worked at Barnbow tank factory in Leeds for 14 years, tank hulls & turrets are not dipped surprisingly! After being welded & machined they are shot blasted, then sprayed first with primer, then top coat. The armoured steel parts of a tank don't generally rust much, due to the metals that armoured steel is alloyed with making it rather more rust resistant, as well as being harder than mild steel.
