Forgive my ignorance but is it just me or are most “Tiger” late version1/35 models sold out. RFM, DRAGON and MENG all seem to be unavailable
Sold Out!
I have the Trumpeter Mid version. Looks a cracking kit. also the 3D decal zimmerit is very handy
Here is the Late version and it is availableComment
If you want an accurate model, then the Academy/Airfix one is not a great choice. It has the wrong turret shape, for one, being designed probably before its true plan became commonly known. If you get a version with interior then it has some even more obvious mistakes, like ammo racks in the sponsons that are only three rounds wide instead of four (because Academy wanted the turret to have the usual bayonet tabs to secure it to the hull, so the racks needed to be narrower).Comment
Do you have a brand that
I think I would go for any modern kit, designed/released in the last 20 years or so, but not one from earlier. But I’m far from an expert on this particular type of tankComment
Try Border Models Tiger 'E',https://www.hannants.co.uk/product/B...lt-token=Vb9cl
As to accuracy - well I think most models have shortcomings, it depends on what you are prepared to accept!
Good Hunting!
DaveComment
It’s too easy to get hung up on (in)accuracy, and what really matters is if you think the model is good enough for your standards.
The main inaccuracy I referred to, by the way, is that older kits (and drawings) of the Tiger I have a symmetrical turret, when viewed from above, with the gun off-centre to the right. It was discovered 25 years ago or so that actually, the gun is centred in the turret but that is wider on the left than on the right. It’s fairly subtle, but you can fairly easily spot the difference on a model, especially if you know it and/or can compare an accurate and an inaccurate one side by side.Comment
Thanks Ian, but it is the late version I’m after as I’m hoping to do a Normandy DioComment
